Can it be welded by an engineer or do i start looking for a replacement?
IcedJohnno wrote:You are going down the right track by taking this repair to a good engineer. The winch casting will see quite high loads when in use, and a failure under load could have serious consequences.
DEATH_INC wrote:IcedJohnno wrote:You are going down the right track by taking this repair to a good engineer. The winch casting will see quite high loads when in use, and a failure under load could have serious consequences.
Maybe, but the loading is being pulled into the break rather than trying to pull it apart. A half decent weld will hold that no problem.
I'd weld it, and make that plate arrangement pictured as well if you're worried about the strength.
IcedJohnno wrote:I see what you are getting at but dissagree.
Those bolt mounts on the front are designed to be part of the winch mount. Thus they will counter some of the torque loading generated by the winch load via the drum and worm box.
As such these bolts will see a tensile load in countering the torque.
(See the web added to the casting in the above photo to help react against the torque/ tensile loading)
The above drawing will help, however you are relying on the front faceplate not to twist.
As I wrote above, winches generate high loads. These are often higher than we perceive.
