Anyone able to have a quick measure of their rear diff for me. I have the housing only, it measures 1350mm
http://www.offroadexpress.co.nz/Forums/ ... &start=165
KZJ71 diff length disc face to face ???
Re: KZJ71 diff length disc face to face ???
I can have a look when i get home Jezza. I think the surf ones are wider or the same width as the kzj's.
Quick measurement taken...
Outside of disc face is 1320..
Then to the face the wheel bolts to is another 110..
Making total of 1430 between wheel mating faces....
Give or take a few mm
Disc face to face... not really that clear aye, sorry, I did mean the face where the rim bolts to. Cheers for reading my mind kbushnz
and buggar, hoped it would be wider. My std Navara is 1480 face to face (plus 20mm spacers) Oh well, surf housing with spacers it is
Jeremy, just a reminder the 71 and 78 have a offset tear pumpkin
vvilly wrote:Jeremy, just a reminder the 71 and 78 have a offset tear pumpkin
Oh f@#k... What housing do I have then? Centre pumpkin, 4 link setup, 8 inch locker, 5 bolt flanges, 1350mm flange face to flange face (where the axel bearing part bolts up)
Jeremy
Which is the same as the one in the rear in mine
Ta, Have ya measured it for me yet?
I'm still waiting for you to come round
Thanks for ya help
if its any help had a measure up around home,
kzn185 surf diff was about 1520 (measued with wheels on)
vzn130 surf seemed to be 1500
and gq safari was about 1590
