cracked head?
Posted: Thu Feb 21, 2013 3:44 pm
by mayhem1982
am i correct in presuming that if my truck is getting hot and the radiator and thermostat are good that it is my head?
when i take the radiator cap off it bubbles and the water level pulses up and down.
there is no water in the oil
Re: cracked head?
Posted: Thu Feb 21, 2013 3:49 pm
by lownslow
You could get a leak down test done to confirm gasket / head
Re: cracked head?
Posted: Thu Feb 21, 2013 3:52 pm
by kbushnz
lownslow wrote:You could get a leak down test done to confirm gasket / head
And also there is a test strip you can buy to dip in the rad water to check for combustion gasses..
Re: cracked head?
Posted: Thu Feb 21, 2013 3:54 pm
by mayhem1982
ok cool. where would i go to get a leak down test? or can i buy those strips from repco or something?
was thinking about replacing the hand grenade with something solid axle, this has just made my mind up for me.
Re: cracked head?
Posted: Thu Feb 21, 2013 4:32 pm
by stealth
You have to wonder how the air is getting into the system for water to bubble out the radiator, mine is also has the same symtoms, best case hg worst case head, either way while its apart you might as well future proof it the best you can
Re: cracked head?
Posted: Thu Feb 21, 2013 5:59 pm
by mudbugga
I'm assuming you have a 1KZ ......
a leak down sometimes won't show up a crack as the valves are closed during the test and the heads crack in the intake ports above the valves.
I've found it's better to remove the glow plugs, pressurise the cooling system and leave it for 10mins or so, then disconnect the plug on the injection pump, and crank the engine over.
If cracked, the coolant will squirt out the glow plug holes.
Plus you can inspect the glowies while they're out.
Re: cracked head?
Posted: Thu Feb 21, 2013 7:31 pm
by mayhem1982
just did that, definately has a cracked head.
and no its not a 1kz its a 2lte
