cracked head?
mayhem1982
cracked head?
Post by mayhem1982 »
am i correct in presuming that if my truck is getting hot and the radiator and thermostat are good that it is my head?
when i take the radiator cap off it bubbles and the water level pulses up and down.
there is no water in the oil
lownslow
Re: cracked head?
Post by lownslow »
You could get a leak down test done to confirm gasket / head
kbushnz
Re: cracked head?
Post by kbushnz »
lownslow wrote:You could get a leak down test done to confirm gasket / head
And also there is a test strip you can buy to dip in the rad water to check for combustion gasses..
mayhem1982
Re: cracked head?
ok cool. where would i go to get a leak down test? or can i buy those strips from repco or something?
was thinking about replacing the hand grenade with something solid axle, this has just made my mind up for me.
stealth
Re: cracked head?
Post by stealth »
You have to wonder how the air is getting into the system for water to bubble out the radiator, mine is also has the same symtoms, best case hg worst case head, either way while its apart you might as well future proof it the best you can
mudbugga
Re: cracked head?
Post by mudbugga »
I'm assuming you have a 1KZ ......
a leak down sometimes won't show up a crack as the valves are closed during the test and the heads crack in the intake ports above the valves.
I've found it's better to remove the glow plugs, pressurise the cooling system and leave it for 10mins or so, then disconnect the plug on the injection pump, and crank the engine over.
If cracked, the coolant will squirt out the glow plug holes.
Plus you can inspect the glowies while they're out.
mayhem1982
Re: cracked head?
just did that, definately has a cracked head.
and no its not a 1kz its a 2lte
