hilux surf sucking power steering fluid into engine oil
golfo1
Newbie
Newbie
Post by golfo1 »
Am having problems with my toyota hilux surf 1994, 2.8l diesel. It appears that the fluid from my power steering system is being sucked into the engine oil. As i have put several litres in over the last week and while the power steering system never fills up, the engine oil level is rising and becoming watered down. White smoke is also coming out the exhaust at times. No power steering fluid is leaking anywhere. and the water level in the radiator remains the same. Im pretty sure the power steering pump is not belt driven. I have read about several things such as vacuum idle up valve, does this model vehicle have these? How could the power steering fluid be entering the engine oil? Also the aircon has been disconnected im not sure if this has any effect on the problem?
evolution02
Re: hilux surf sucking power steering fluid into engine oil
Post by evolution02 »
I think you will find yours is KZN130 with a 3litre turbo 1kzte engine. Not 2.8 as you have said
If yours is a 1kz the answer to your oil issues will be seals down at the engine driven powersteering pump leaking thru.
On the 1kz engines the power steering and engine vacuum pumps are driven thru gears of the bottom of the engine
Follow the hose down from your power steering reservoir to find the pump
