WTB Hilux front drive shaft for high angle operation
churchill
Post by churchill »
I'm after a Double Cardan style front drive shaft from a hilux etc that will fit a 8" toyota diff. I think most Hilux run this setup, correct me if I'm wrong.
I've got Hilux axles under my Zuk but the front driveline angle is to extreme and I've run out of spline. I need 75mm travel and only have 90mm available meaning i'll be driving with 15mm engaged at full droop. That's not enough!
Anything considered.
mudlva
Re: WTB Hilux front drive shaft for high angle operation
Post by mudlva »
ive heard of hilux a/m driveshafts splines that are 300mm long if i can remember correctly
ex aussy i think
churchill
Post by churchill »
Shizer, do you know what standard length is?
mudlva
Post by mudlva »
no
its just some thing that was mentioned here a good while back
suzolla
Post by suzolla »
You mean something like this
http://www.trail-gear.com/drive-shaft-kit
Tim
Ralfie
Post by Ralfie »
Terrain Tamer would be a good place to start.
Don Kyatt in Manukau are the Auckland agents.
Big
Post by Big »
whats ya compressed and extended lengths..? as I have one as had to change to a longer one for front..
churchill
Post by churchill »
588mm compressed and 663mm extended. Driveline angle at transfer 34°...
Hi Tim, it's more the the new one in the link:
http://www.pirate4x4.com/tech/billavista/PR-shaft/DCP_6524.JPG
