Wanting to swap, Sanden air con pump
kiwipete
Post by kiwipete »
Hello all, I have a Sanden SD709 air con pump suitable for endless air conversion that I would like to swap for a smaller SD508 pump please.
Space is an issue and I cannot fit the larger 709 in place where I want it to go.
The 709 unit has a twin V belt pulley clutch on it and I would like the same on the 508.
So if someone wants a larger air pump, please contact me.
And some pictures for those of you who like pictures :wink:
This is the SD709 that I have.
This is what I want to swap it for.
A Sanden SD7B10 that I will use in place of my factory air con unit, this one is much smaller. I want to retain the on board air con and to squeeze the air compressor between the factory air con and alternator means I have to downsize something. I cannot see an issue with using this smaller AC unit.
The three units side by side. SD709, SD7B10 and the Factory unit.
Ph 0212078472
rokhound
Re: Wanting to swap, Sanden air con pump
Post by rokhound »
Any idea which vehicles were fitted with the 709 and 508 as a standard compressor Pete?
tomsoffroad
Flopsie
Post by tomsoffroad »
rokhound wrote:Any idea which vehicles were fitted with the 709 and 508 as a standard compressor Pete?
Id quite like to know this too please :D
SMOKEY
Post by SMOKEY »
Hi Pete, not totally sure but I think the clutch pulley assembly should be swappable , unless the shaft taper is different. If you need to change we have a AC puller set at work. :( I won't tell you what I threw out at work about a month ago :oops: ,
KEEP WORKING,
FITZY.
kiwipete
Post by kiwipete »
Rockhound and Tom
If I tell you I will have to kill you all :lol: :lol: :lol:
NZ new 90's Galant/Lancer had the 508 as did 83-85 Mazda 626's from what I have found; oh and some older European cars too.
I do not know what the 709 came in, if you find a 508 and want a 709, then I have one here for you. :wink:
Smokey
Don't tell me, I might :cry:
Ph 0212078472
kiwipete
Post by kiwipete »
I have a pdf file of the service manual for the following Sanden Model Conversions if anyone needs one.
Type R-134a R-12
5 Cylinder SD-505 SD7B10 / SD5H09
SD-507 SD5H11
SD-508 SD5H14
SD-510 SD7H15HD and SD5H14HD
7 Cylinder SDB-706 SD7B10
SD-708 SD7H13
SD-709 SD7H15
SDB-709 SD7B15
Ph 0212078472
kiwipete
Post by kiwipete »
Just a wee update, I think I may have found a Sanden SD7H15 air con pump.
Can anyone confirm if this may be suitable to modify like the SD508's?
Ph 0212078472
