L200 Diff Swap
Posted: Fri Jul 26, 2013 1:36 pm
by troyfield
Hi all, just signed up to this forum, own a 1994 L200 and looking to do a few mods. Has anyone done a diff (or diff head) swap to get more top end speed ? I spent the weekends off road but do a lot of open road driving during the week, with my standard 4.625 diff ratios im pulling 3000rpm at 100km/h and want to drop this down a bit. Anyonw know if the later model L200/Triton/Pajero diffs heads fit ? After around a 3.9 ratio.
Any help/advise would be much appreciated.
Cheers, Troy
Re: L200 Diff Swap
Posted: Fri Jul 26, 2013 3:19 pm
by nizute
so you want to do less rpm at a 100km/h or more? and what engine is in your l200?
Re: L200 Diff Swap
Posted: Fri Jul 26, 2013 5:08 pm
by zukmeista
troyfield wrote:im pulling 3000rpm at 100km/h and want to drop this down a bit. Cheers, Troy
Re: L200 Diff Swap
Posted: Fri Jul 26, 2013 5:55 pm
by nizute
well the easiest way is to put bigger tyres on it if you want to gear it up .
I am presuming its diesal, when does its "power band"(
) kick in?
Re: L200 Diff Swap
Posted: Fri Jul 26, 2013 9:55 pm
by diogenese
Are you sure you have 4.625 diffs? My L200 is running at 2400 rpm at 100km/h.
It is a '91 2.5 turbo diesel doublecab with a 5 speed manual 'box.
it's on 31" maxxis mudders.
Re: L200 Diff Swap
Posted: Fri Jul 26, 2013 11:11 pm
by nizute
My navara dropped 500rpm when i put my 31inch tyres on.
What size were the original sized tyres on your ute.?
Re: L200 Diff Swap
Posted: Mon Jul 29, 2013 10:01 am
by troyfield
It has the standard 4D56 turbo diesel engine in it. It has three stickers on the the rear diff, C88, Use only LSD Oil, and 4.625 so am assuming the last one is the ratio. Unsure of the original tyre size, currently has 235/75/15 on it.
Re: L200 Diff Swap
Posted: Mon Jul 29, 2013 10:14 am
by nizute
do you know anyone who has a set of 31x10.5x15?
At what rpm does you power sart and finish? in my navara it starts about 2500 and peaks off about 3500
Re: L200 Diff Swap
Posted: Mon Jul 29, 2013 10:36 am
by troyfield
My brother has a set so will try them this weekend. My power starts at around 2000 and stops at around 3000.
Re: L200 Diff Swap
Posted: Mon Jul 29, 2013 10:04 pm
by diogenese
http://www.tacomaworld.com/forum/tireca ... 15-31-10.5That's about 7% bigger for the 31's, or around 170 rpm less at 100kmh
I think my earlier gearbox has a taller ratio 5th gear but it is much weaker than the later ones so no good for towing.
Re: L200 Diff Swap
Posted: Wed Jul 31, 2013 8:48 pm
by troyfield
What year is yours ? Do you know your gearbox ratios ? I had also heard the earlier models had taller (but weaker) 5th gears. Im not too worried about this as i will stay in 4th to do any heavy towing.
Re: L200 Diff Swap
Posted: Thu Aug 01, 2013 8:25 pm
by diogenese
I have a '91 Strada. It's a JDM import version of the L200 and it has the early gearbox but I'm not sure of the ratios.
If you do a search on here I think there is a post with the gearbox codes and ratios.
