ID this Tie Rod end
Posted: Mon Dec 02, 2013 7:13 pm
by lilpigzuk
Anyone able to identify this tie rod. Fairly sure its Toyota as the vehicle has 40 series running gear. BNT nearly got it right, but the bit I need in 14mm was 12mm. They soon gave up after that since they weren't dealing with the "original vehicle"
Re: ID this Tie Rod end
Posted: Mon Dec 02, 2013 7:27 pm
by turoa
From that it looks like an 80 series tie rod end but someone would probably have to measure to be sure
Posted: Mon Dec 02, 2013 7:35 pm
by mudlva
60/70 rhs end
could also be steering link as well
Posted: Mon Dec 02, 2013 7:47 pm
by lilpigzuk
Thanks so far. 80 series is 23mm main thread size... Keep up the suggestions
Posted: Mon Dec 02, 2013 8:16 pm
by mudlva
didnt check the thread but i have a end here that measures 14d x 77 with 21mm main shaft dia
its for a steering link end on a 60 i think
Posted: Tue Dec 03, 2013 7:45 am
by kbushnz
Its not a Square shape Prado one... Same thread dia's..But the lengths are longer on the Prado one for the 21mm dia shaft...
Posted: Tue Dec 03, 2013 7:57 am
by muddy
I'd go with 60 series. They are a size bigger than 40's and commonly used in a power steering upgrade...
Posted: Tue Dec 03, 2013 6:58 pm
by Big
This just for reference for others as I had one in my parts bin..
Off an 80, measurement's are crude as I rounded everything up to the mm.. not sure if left or right as I just unscrewed it from a spare steering arm..
enjoy
Posted: Tue Dec 03, 2013 8:38 pm
by foreign
hilux or surf. think they are 21x1.5mm
Posted: Tue Dec 03, 2013 9:45 pm
by mickey
lilpigzuk wrote:Anyone able to identify this tie rod. Fairly sure its Toyota as the vehicle has 40 series running gear. BNT nearly got it right, but the bit I need in 14mm was 12mm. They soon gave up after that since they weren't dealing with the "original vehicle"
I've got a FJ40 front diff in the garage with tie rod attached.
The rod end seems to be very close to the one in the picture.
Came out of a 1976/77 FJ40.
Posted: Mon Dec 19, 2016 6:12 pm
by tommie
I know old topic but did anyone find out what this was from in the end?
Posted: Mon Dec 19, 2016 6:18 pm
by Rotazuk
Yep . But cant remember
. Let me think about it . I am leaning to 80 series .
Posted: Mon Dec 19, 2016 7:19 pm
by tommie
80 series is 23mm got one of those in hand but the one I need is 21mm
Posted: Wed Dec 21, 2016 7:57 pm
by churchill
Solid axle hilux is my pick. Sane as 80 series bit with a M21x1.5 thread.
