ID this Tie Rod end
Re: ID this Tie Rod end
From that it looks like an 80 series tie rod end but someone would probably have to measure to be sure
- mudlva
60/70 rhs end
could also be steering link as well
Thanks so far. 80 series is 23mm main thread size... Keep up the suggestions
- mudlva
didnt check the thread but i have a end here that measures 14d x 77 with 21mm main shaft dia
its for a steering link end on a 60 i think
Its not a Square shape Prado one... Same thread dia's..But the lengths are longer on the Prado one for the 21mm dia shaft...
I'd go with 60 series. They are a size bigger than 40's and commonly used in a power steering upgrade...
This just for reference for others as I had one in my parts bin..
Off an 80, measurement's are crude as I rounded everything up to the mm.. not sure if left or right as I just unscrewed it from a spare steering arm..
enjoy
enjoy
hilux or surf. think they are 21x1.5mm
I've got a FJ40 front diff in the garage with tie rod attached.
The rod end seems to be very close to the one in the picture.
Came out of a 1976/77 FJ40.
I know old topic but did anyone find out what this was from in the end?
- Rotazuk
Yep . But cant remember
. Let me think about it . I am leaning to 80 series .
80 series is 23mm got one of those in hand but the one I need is 21mm
Solid axle hilux is my pick. Sane as 80 series bit with a M21x1.5 thread.
