egr butterfly
Posted: Thu Mar 20, 2014 8:38 pm
by Waddles
ok lads another dumb ass egr q :roll: i know ha since i have been able to park my safari up 4 a bit i decided to finally get around to removing the egr.
after a few bad words i have got it all off and now cleaning all the shiet out of the manifold i have removed the butterfly as well but need to know what you boys have used to block the pivot holes were the fly was got me a bit stumped :?
Re: egr butterfly
Posted: Thu Mar 20, 2014 8:45 pm
by Crash bandicoot
Waddles wrote:ok lads another dumb ass egr q :roll: i know ha since i have been able to park my safari up 4 a bit i decided to finally get around to removing the egr.
tap and die set with some bolts and loctite.
Re: egr butterfly
by Mattman
X2
Re: egr butterfly
Posted: Thu Mar 20, 2014 8:53 pm
by Waddles
sweet i did think that but with a nut and bolt wasn't sure if it was trust worthy ha thanks!
apart from the vac lines (i have already blocked) is there any electrical plugs or sensors i need to be aware of? i herd there a water temp sensor for it on the nissans is it the front 1?
Re: egr butterfly
Posted: Thu Mar 20, 2014 9:01 pm
by Mattman
You will struggle to get a perfect seal with a but and bolt. Make sure you use plenty of thread locker if you go that route.
Matt.
Re: egr butterfly
Posted: Thu Mar 20, 2014 9:16 pm
by Waddles
year il get it tapped
Re: egr butterfly
Posted: Fri Mar 21, 2014 1:14 pm
by Bonus
I used Selleys Knead it, worked a treat been sweet now for over a year
Re: egr butterfly
Posted: Sat Mar 22, 2014 7:23 pm
by Waddles
shellys kneed it that stuff is amazing :D it does work a treat cheers
