Jimny with 15x7 Rims
Posted: Wed Jul 16, 2014 11:00 am
by obansam
Hi,
This question has probably been asked over and over again...but
if I change my stock Jimny rims (15x5.5) for 15x7 with a -15 offset fitted with 215/75 muds (not sure which brand yet), am I likely to have any scrubbing issues?
I currently have a 40mm OME suspension lift, all the rest of the running gear is stock.
Andrew
Re: Jimny with 15x7 Rims
Posted: Thu Jul 17, 2014 7:52 am
by COILY
Assuming it is a 1998 on Jimny? 215's will be to narrow for 7'' rims. If you go to 235s you will need at least a 50mm body lift with the suspension lift and some trimming. Jimny's have small wheel arches.
Posted: Thu Jul 17, 2014 9:00 am
by obansam
Yup 2012 Jimny, I think I'll stick with my standard rims for a while, I don't want to do a body lift or start cutting guards.
Posted: Thu Jul 17, 2014 7:59 pm
by COILY
Its only plastics that need trimming.
Posted: Fri Jul 18, 2014 5:33 pm
by hunter1084
Doesn't say anything about rim size but thought this might be usefull
http://www.bigjimny.com/index.php/forum ... 1978#93064
