Jimny with 15x7 Rims
For all Suzuki related topics
obansam
Post by obansam »
Hi,
This question has probably been asked over and over again...but :D if I change my stock Jimny rims (15x5.5) for 15x7 with a -15 offset fitted with 215/75 muds (not sure which brand yet), am I likely to have any scrubbing issues?
I currently have a 40mm OME suspension lift, all the rest of the running gear is stock.
Andrew
COILY
Re: Jimny with 15x7 Rims
Post by COILY »
Assuming it is a 1998 on Jimny? 215's will be to narrow for 7'' rims. If you go to 235s you will need at least a 50mm body lift with the suspension lift and some trimming. Jimny's have small wheel arches.
obansam
Post by obansam »
Yup 2012 Jimny, I think I'll stick with my standard rims for a while, I don't want to do a body lift or start cutting guards.
COILY
Post by COILY »
Its only plastics that need trimming.
hunter1084
Post by hunter1084 »
Doesn't say anything about rim size but thought this might be usefull
http://www.bigjimny.com/index.php/forum ... 1978#93064
Return to “Suzuki”
