quick lift
fish
quick lift
Post by fish »
anyone had experience with this style kit? seems popular with the yanks and pretty simple. would this need a cert? thoughts.
http://www.ebay.com/itm/JEEP-Grand-Cher ... 37&vxp=mtr
lax2wlg
Re: quick lift
Post by lax2wlg »
They call it a 'budget boost.'
Aint nothin wrong with it
wranglerbabe
Re: quick lift
Post by wranglerbabe »
I am also thinking of doing this with my Jeep wrangler. Much cheaper than new springs and shocks. I figure it will give me a good feel for the height, let me save for some new tyres and then I can decide to stay at that height or go higher with springs etc.
lax2wlg
Re: quick lift
Post by lax2wlg »
Yeah they put a lot of thought into setting up the factory suspension to deliver perfect articulation balance and overall performance (on and off road).
In many ways its good just to leave it alone as it is such a good setup.
Often these aftermarket springs give no consideration to performance and are too stiff etc.
I'd put the money towards lockers.. then performance-wise youre rubbing shoulders with the Rubicon Unlimited... the most capable production 4x4 in the world.
wranglerbabe
Re: quick lift
lax2wlg wrote:Yeah they put a lot of thought into setting up the factory suspension to deliver perfect articulation balance and overall performance (on and off road).
So spring spacers and lockers would be the way to go then?
Let's get a little mud on the tires - Brad Paisley
00falcon
Re: quick lift
Post by 00falcon »
Lockers are expensive and serious...
I have a 2.5" spring lift with Simex, and its not that often the guys with lockers get thru what i cant...
and hey, its a bit of fun when i have to get dragged out...
My Shopping/Upgrade list is a mile long...
how much of it will happen is another story...
but even so, a (Select-able) locker is a long way down.
My feeling is i would rather re-gear now, and lock later, as i think you require a different locker/carrier once you go up from 3.73.
Also, even with a budget boost, don't you need new shocks...?
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
lax2wlg
Re: quick lift
Post by lax2wlg »
Oh please dont base your decision solely on what I'm saying.. I'm just saying what I would do is stuff 33x10.5 BFGs into the standard suspension, swaybar disconnects, lockers front/rear, and lower gears in the differentials 5.13, 5.29. Then you would have a total sleeper.
I'm guessing your aim is to fit bigger tyres.
I would fit the tallest tyre/rim combo possible without lifting it.
I guess a lot of it comes down to the type of 4x4 activity one is engaging in.
What sort of terrain are we talking about... are we talking about this high revving mud bogging winch challenge type stuff which seems to be popular, or are we talking technical inch by inch crawling up high traction rock faces, or idling through rocky river beds, or massively undulated ruts etc...?
TJ
Re: quick lift
Post by TJ »
Without lifting a TJ, the biggest tyre you can go is 31s. If you don't like your fenders, go bigger with no lift and adjustment to the bump stops.
Budget boost with factory shocks will mean now the shocks are your limits for axle drops.
wranglerbabe
Re: quick lift
Ok, so, are spring spacers a good way to go for someone on a budget, wanting a bit more height without any serious mods?
fish
Re: quick lift
Post by fish »
wranglerbabe wrote:Ok, so, are spring spacers a good way to go for someone on a budget, wanting a bit more height without any serious mods?
my question exactly, if so i will do shocks with it as mine are spongy.
is there any real negative to a 1.5 - 2 inch spacer lift?
TJ
Re: quick lift
Post by TJ »
If you are going to the trouble of taking the springs off to put these on and changing the shocks, might as well put lifted springs in at the same time. Get the springs and shocks matched for height and performance and there will be no troubles. I am not a fan of these short cuts as they eventually have to be replaced. Get springs from a reputable Jeep related brand. Chances are you will over compress the factory springs with these on when you are on the compressed side, which basically is a recipe for sagging.
If you stick to around 2" lift with springs, nothing much needs to be done to other drive components. SYE and stuff becomes necessary for taller lifts or if you damage your transfer case. 2" lift on a TJ gets you 32" tyre easily.
pmfg
Re: quick lift
Post by pmfg »
I have 2 inch polly spaces, And when I get the money I will be changing them for a spring and shock lift kit. I just dont like the look of these poly spaces.... something just doesnt feel right, like its a job half done or something, thats just me though.
WideLoad
Re: quick lift
Post by WideLoad »
Little off topic, but the comment above about lockers being to expensive isn't entirely true. I put a Aussie Lokka in the front of my TJ and was only $300 delivered to my door plus some diff oil and was easy enough to install. Would have to be the best mod I've done and made the biggest difference to offroad ability without affecting the road habits, other than a lil clicking on tighter corners.
TJ
Re: quick lift
Post by TJ »
Auto lockers are a good option.
fish
Re: quick lift
Post by fish »
and does it need a cert?
TJ
Re: quick lift
Post by TJ »
fish wrote:and does it need a cert?
No.
wranglerbabe
Re: quick lift
How high can you go before needing a cert?
XJCrawler
Re: quick lift
Post by XJCrawler »
Correct me if I'm wrong but maximum is 50mm above stock.
Go all out get a long arm, chromolys and lockers be sick as lol
TJ
Re: quick lift
Post by TJ »
XJCrawler wrote:Correct me if I'm wrong but maximum is 50mm above stock.
Technically, you are incorrect. Limit is not specified in numbers as such.
lax2wlg
Re: quick lift
Post by lax2wlg »
The other option with the budget boost is to just keep your existing shocks and mod the bumpstops to compensate.
ie it is literally a budget boost just to gain a bit more room to fit taller tyres, not actually increase wheel travel, preventing situations where the springs will want to fall out etc
Coil spacers are accepted as being a good solution when setup correctly. Just dont go crazy on the height :)
slidenyo
Re: quick lift
Post by slidenyo »
the old adage "the cheapest option is always the most expensive" springs to mind.
there is absolutely nothing wrong with 31 mt's on a small 4x4 in fact it can be an advantage.
tire width selection and wheel offset can be the difference between running a 31 and a 32.
running big offset can see the tires take the wear that normally the body might cop running through deep ruts and high angled sidlings,
but it can introduce other issues
lax2wlg
Re: quick lift
Post by lax2wlg »
Theres absolutely nothing wrong with or half arsed about modest-sized coil spacers if setup correctly, and you are looking for a little bit of lift without messing up the standard suspension setup.
Coil spring rate: function of static length (longer, more lift), wire diameter (lower diameter, easier to compress) and number of coils (more coils, lower spring rate.)
They spent a lot of time/research getting the suspension to work well on the TJ. By fitting aftermarket springs you are disregarding all of this.
I'm not saying dont do it, I'm just saying think about where it will get you. Aftermarket springs will generally have a thicker wire diameter so actually articulate less.
As for the Grand Cherokee, Chrysler used about a million different spring rates depending on the model... Its insane... as an example a good mod for Pathfinders is to put Jeep ZJ (Grand Cherokee) front springs in the back... between 92-97 there were over 12 different spring rates used, depending on I6, V8, Upcountry model, tow model, skid plate etc etc.
Aftermarket springs are generally one size fits all, so be ready for it :D
TJ
Re: quick lift
Post by TJ »
lax2wlg wrote:Aftermarket springs are generally one size fits all, so be ready for it :D
Generally, yes most producers just go with one spring rate. However, companies like ARB/Old Man Emu, Currie Enterprises, AEV and similar higher end producers do have springs for the same model in different configurations. AEV work very closely with Jeep/Mopar for development work.
Return to “Jeep”
