front driveshaft for the mu
Posted: Wed Mar 14, 2007 7:53 pm
by daisy
Posted: Thu Mar 15, 2007 5:36 pm
by SupraLux
I think the sleeve goes to the top from memory but it shouldn't affect the operation... just make sure you have the UJs aligned (if you've slipped the slip-joint apart) otherwise you could end up with driveline vibration.
It always pays (as I'm sure you've figured out by now
) to mark everything with a white marker before you start pulling it apart...
Steve
Posted: Fri Mar 16, 2007 4:26 pm
by daisy
Posted: Fri Mar 16, 2007 7:21 pm
by nhawke
It doesn't matter what way you putt the drive shaft in so long as both UJ's are in line, as the diff is fixed in place. So long as your not doin high speed in 4wd you shouldn't need to get it balanced.
Nathan
Posted: Fri Mar 16, 2007 7:51 pm
by mud_slinger
on ma piece of broken shit the sleeve that the shaft slides in to is on transfer case end
Posted: Fri Mar 16, 2007 9:52 pm
by daisy
