LSD's
ruf_zuki
LSD's
Post by ruf_zuki »
the lsd unit can be removed from .. say a 4.1 ratio diff into a 4.88 cant it ?
because it only effects the spiders not the crown and pinion
correct me if im wrong please
oldblue
Post by oldblue »
You will need to measure the thickness of the ring gear, if its the same , then it will change over.
There is a thinkness differance at a certain ring gear ratio. not quite sure where that changover is.
MATT4U
Post by MATT4U »
yes you can ,I have done it
ruf_zuki
Post by ruf_zuki »
timotheus
Post by timotheus »
Sorry to dig up old shit but, is this the same for 4.3 to 4.5?
I just got a 4.3 cheap and thought id do the swap thing.
Also can anyone link me to a thread on diff rebuilds?
I cant find one.
Chairs Tim.
LOLYF
Post by LOLYF »
timotheus
Post by timotheus »
LOLYF wrote:http://www.gearinstalls.com/
Well bugger me, there goes the next months reading....
