I just got this email from someone asking me, so I said Id ask on here for him.
"Hey dude,
Do you know if I can get rid of the vaccuum 4wd and run a lever? or can I run a vaccuum switch to run the H4?
Also, can I run a PTO on my prado? its an auto? I have heard that you have to take the PTO gear out of something else??
Cheers man
Jim"
Can anyone help this man out?
lj78 vaccum 4wd? and also PTO
Re: lj78 vaccum 4wd? and also PTO
turoa wrote:Also, can I run a PTO on my prado? its an auto? I have heard that you have to take the PTO gear out of something else??
I know some transfer cases have the PTO drive gear and some dont. The split transfer case on my 70# only has a spacer on the shaft where the drive gear goes
NO he can't have the drive gear out of my spare transfer case
NJV6
wjw
oldblue
70s Prado's were classed as a light duty cruiser so don't have a PTO Gear in the T/F box, so there was no provison in the floor pan for the PTO lever.some Prado's were fitted with an electric Toyota 12volt winch.
You can use the PTO Gear and spacer from the earlier 70s T/F case.
oldblue
pradojim
- Stropper
oldblue
