4x4 or 4wd
When you refer to your 'truck' is it a 4x4 or a 4wd??
4x4
6
16%
4wd
11
30%
4x4 and 4wd... It don't matter! They both mean the same thing. I don't care!
17
46%
Neither!... I refuse to take part in a poll that is so trivial! (or, my truck has seven wheels and doesn't apply.)
3
8%
Total votes: 37
Azza
4x4 or 4wd
Post by Azza »
:?: When you refer to your 'truck' is it a '4x4' or a '4wd'??
Have you ever imagined a world with no hypothetical situations?
TJ
Post by TJ »
I believe the term 4wd became popular once all these "soft" off-roaders came on the road. These are also called All Wheel Drives.
I drive the original and use the term 4x4.
The jeep isn't the original 4x4 :lol:
http://en.wikipedia.org/wiki/4x4#History
Azza
Post by Azza »
TJ wrote:I believe the term 4wd became popular once all these "soft" off-roaders came on the road. These are also called All Wheel Drives.
Am I right in saying though that a 4wd is not really the same as an Awd and visa-versa because of the technology used??, But I'm guessing you are refering to 'IFS', Invented For Shopping (love that term :wink: ), Urban 4wd's and the like, the wee beasts that mum's take the kids to school in?? :wink:
TJ wrote:I drive the original and use the term 4x4.
Spoken like a true jeep owner :wink: :lol:
TJ
Post by TJ »
Details... :lol:
It wasn't till the Willys/Jeep started the trend that 4x4s became a main stay for civilian use. Let me correct it then, I drive the trendsetter and use the term 4x4.
TJ
Post by TJ »
Azza wrote:Am I right in saying though that a 4wd is not really the same as an Awd and visa-versa because of the technology used??, But I'm guessing you are refering to 'IFS', Invented For Shopping (love that term :wink: ), Urban 4wd's and the like, the wee beasts that mum's take the kids to school in?? :wink:
The likes of CRV and RAV4 normally have 4wd written on the sides. Subaru uses the term all wheel drive. Audi uses the term quattro. Non of these have low boxes, so I call them soft off-roader.
As for my comment, well I am a Jeepaholic through and through.
Azza
Post by Azza »
TJ wrote:The likes of CRV and RAV4 normally have 4wd written on the sides. Subaru uses the term all wheel drive. Audi uses the term quattro. Non of these have low boxes, so I call them soft off-roader.
So I guess that if you don't have Hi/Lo ratio in your truck then you have a 4wd
So what makes a 4x4?? (other than being a jeep! :wink: ) if I have Lo ratio does it mean I have a 4x4 and not a 4wd??
TJ
Post by TJ »
As long as you don't have a a full-time single-speed system designed to supply drive power to all four wheels (i.e. AWD or 4WD), you are driving a 4x4 in my book. On a CRV, you have no choice it just works on its own depending on wheel spin and load.
Most of here would have 4H and 4L available to us (most of the time), so these would all be 4x4s.
This is not questioning whether you have full-time or part-time system. Thats a whole different debate. For example, Wranglers have a part-time system and can shift into 4H on the fly, but I cannot drive on hard pavement in 4H or 4L without distroying my drivetrain. My transfer case is locked internally to supply power to both ends (front and back) when 4H or 4L is engaged. A Grand Cherokee has a full-time system that splits the torque based on slippage (viscous coupling) in the transfer. These are both 4x4 as they have 4H and 4L.
Mark
Moderator
Post by Mark »
To me 4x4 is an American thing, and you need to say it properly... fourrrrrrrrbarfourrrrrrr (with rich southern roll of the rrrrrrrrr). Other then the uncouth bunch down the far south nobody else in NZ can say it properly.
As for the Hi/Lo bit... some Subaru Outbacks (or is it the Jap version - Grand Wagon or something) have Hi/Lo and they are just Awd. If it's got a centre diff and is always driving every wheel then it's Awd. Some Awd's can lock the centre diff which would then make it a 4wd.
Hahaha... how's that? Who the hell knows really. By coincidence (I looked this up after I typed the above) here's what Wikipedia says:
Four-wheel drive, 4WD, or 4x4 ("four by four") is a four-wheeled vehicle with a drivetrain that allows all four wheels to receive power from the engine simultaneously.
The term four-wheel drive describes truck-like vehicles that require the driver to manually switch between two-wheel drive mode for streets and four-wheel drive mode for low traction conditions such as ice, mud, snow, slippery surfaces, or loose gravel. All-wheel drive (AWD) is often used to describe a "full time" 4WD that may be used on dry pavement without destroying the drivetrain (It should be noted that "Full-Time" 4WD can be disengaged, and the center differential can be locked; essentially turning it into regular 4WD. Whereas AWD cannot be disengaged and the center differential cannot be locked.) [1][2], although the term may be abused when marketing a vehicle.
Oh... and it also says:
The Jeep Wrangler is a 4WD vehicle with a transfer case to select low range or high range 4WD.
:wink:
Azza
Post by Azza »
TJ wrote:As long as you don't have a a full-time single-speed system designed to supply drive power to all four wheels (i.e. AWD or 4WD), you are driving a 4x4 in my book. On a CRV, you have no choice it just works on its own depending on wheel spin and load.
Well I have manual locking hubs with optional Hi/Lo 4wd, so I guess I have a 4x4 :D
But.... what happens when I select 2wd?.. :shock: does my 4x4 get degraded to something else?? a 4x2? or a 2wd?
it's all about as clear as the mud that covers my truck :shock: :wink:
Azza
Post by Azza »
Mark wrote:Oh... and it also says:
:wink:
Well, that's just thown a huge spanner in the works! :shock: Now I don't know what to think!
Maybe I have a 4wd masquerading as a 4x4, masquerading as a 4wd.... sheesh!
Az
TJ
Post by TJ »
Well, without locking differentials all 4x4s are really 2 wheel drive anyway. So who really cares what you call them as long as the skiny pedal works and wheels spin when needed.
BTW, wikipedia is edited by just about anybody so always take that information with a grain of salt.
Azza
Post by Azza »
TJ wrote:Well, without locking differentials all 4x4s are really 2 wheel drive anyway.
WTF!! :!: :shock:
Even without locking diffs, surely all 4 wheels are getting power from the engine, even though some are spinning wildly :shock: so... I guess I have a 4x4 except when I don't have full traction, in that case I in fact have a 4x2 or hopefully a 4x3 if conditions are good? :wink:
I know for sure, I probably have a 4wd cause I don't go shopping in it and I have Hi/Lo ratio :lol: must be a 4x4, in theory at least :wink:
But then again, after what Mark posted... perhaps it's really a 4wd and not a 4x4 at all :?: :wink:
Yours in confusion, :? Az
fweddy
Post by fweddy »
In my book its just different ways of expressing similar things.
A 4x4 has four wheels, four of which can have drive to them.
A 2x4 has four wheels, two of which can have drive to them.
A 4wd has an undisclosed amount of wheels but at least four of them can have drive to them.
A 2wd has an undisclosed amount of wheels but at least two of them can have drive to them.
A Awd has an undisclosed amount of wheels but all of the wheels it does have can have drive to them.
It doesn't matter if they all have drive at the same time or not, its about potential :) about mechanical drive trains and diffs and axles.
My guess would be that the term Awd has been used for fulltime 4wd road cars to save confusion with what is become commonly knows as 4wd or 4x4 (interchangeably) which is off road vehicles.
Steve_t647
Post by Steve_t647 »
4x4, fwd and awd are all patiented trademarks they are the same thing just someone painted the word grouping and charged the manufacturers or sold it to them the manufacturers now register every car badge name because of this, cant remember but I think it was a American that did it and sued for breach in the us settled out of court from memory this was when Subaru changed to AWD to avoid the conflict
xj
Post by xj »
What about the Australian-ism "Fourbee" (spelt phoenitically)
Does it all really matter?
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
