toyota diff width info needed please
WACKO
Pyro
Post by WACKO »
righto, toyota guys... please dazzle me with your knowledge...
im after the widths of the toyota axles. ive had a look around and found out that 60s, are 70mm wider than 40s, and 70s are 20 wider than 40, and that doing the ifs mod to a std hilux housing makes it 66mm wider which is also the same width as a surf. now, im just needing to know the width of:
surfs
hilux
60s
and 70s..
cheers guys.
Sam.
Rotazuk
Post by Rotazuk »
Answer to some questions here
http://home.4x4wire.com/erik/diffs/
Chris
WACKO
Pyro
Post by WACKO »
thanks chris. looking at that now im thinking even with ifs hub swap the hilux front wont be as wide as a surf rear... itl still be 20mm or so to skinny.... it isnt much but all those measurements say the front should be slightly wider....
Sam
