Has anyone ever put Maxitrac raised springs and/or shocks in a LN106 Hilux?
I am after wether ya used heavyduty or extra heavy duty springs, and any feed back ya may have regarding ride, flex etc
Dave.
Maxitrac springs in a hilux
Got a Daihatsu Something, hasn't got a Daihatsu engine.... or diffs.... and it doesn't have windows.... or doors.... but its got tyres....
Re: Maxitrac springs in a hilux
ive got a 86 surf with maxitrac rear springs and shocks heavy duty one not sur if they was super heavy duty or not ill put a picture of it flexn up a ramp
They handle grate and flex alright
not bad for a IFS front end, thanks surf
have a chat with steve (supralux) he get them in from oz i think , i brought a set for my saf off steve been on the truck 18mths cant fault them in my whale, but cant tell yer what they would be like in a hilux
vince
vince
Im guessing that if they make these for a ln106 then they would surely have them for a LN130 ????????????
Is there anywhere in wellington that would have them?
Don't Drink And Four Wheel Drive, Those Broken Bottles Are A bitch To Clean Out Of Your Truck.
Nailz wrote:Im guessing that if they make these for a ln106 then they would surely have them for a LN130 ????????????![]()
I can get em thru Repco at a good trade rate
i have them in the front of my ln106 hilux with there shock to. big improvment in flex and road handling over the tired old ones. wernt to harsh when new either. have had them near on two years now and would deffinatly recommend them.
They are fantastic value for money... I've had great reports back from pretty much everyone thats used it. A couple of hickups along the way, but they are covered with a warranty.
I recommend fitting new shocks when you fit the springs, as the factory front shocks are too short - also get a flat-top u-bolt if you are fitting front springs as the packs are thick, and one of the drivers side u-bolts will probably end up fouling the drag link.
They are designed (H-spec springs - heavy duty) to be as close to the factory spring rate as possible, so they are pretty supple and flexy.
J-spec are for load carrying only - they don't flex bugger all.
I can generally work out good deals on packages for people that want them too.
Oh, and LN106 and LN130 are totally different - the 106 is a beam axle leafs front and rear ute, where the 130 is a coil rear IFS front Surf - but yes, Maxitrac does springs for most Hilux and Surf models...
Steve
Steve
have them in my yn60 surf and they go great
