safari turboed truck pic/facts???
Re: safari turboed truck pic/facts???
another thing im wonting to know is what air filter is best to use or what filter does everyone else use??
after some sort of panel one im thinkn
cheers Jacob
cheers Jacob
jA- wrote:another thing im wonting to know is what air filter is best to use or what filter does everyone else use??
cheers Jacob
26 psi pretty good for them it wouldnt get much higher free boosting would it?
i try to use k an n air filters then make a custon box for it to go in
jA- wrote:have heard of guys boring out to 4.5 litres but nothing more than that will be interesting to see how it goes...
im runing a tdo5 at the moment has good spool up, most i've had it up to is 26psi at about 3000rpm but the egt's r round the 620-650 so dont let it go that high very often....
need to get my injector pump recond so that mite be stuffn me up a bit but im pretty happy with it for now!!!![]()
Are you running an intercooler? If not is the inlet manifold standard? 26psi without an intercooler and with the standard inlet manifold is likely to be causing piston damage. With that sort of boost it is highly likely you are getting different amounts of air into the cylinders and so some will be running a lot hotter and some colder than your egt gauge.
You might be OK but I've seen quite a few that have taken out the inner cylinders because of this!
Also don't recond your pump, instead send it to Arron Smythe in Rotorua and get him to do a hybrid job on it. Not a lot more than a normal recond but far far better if running high boost!!!
darinz wrote:jA- wrote:have heard of guys boring out to 4.5 litres but nothing more than that will be interesting to see how it goes...
its not a truck i have done just what he said, i wouldne have thought a turbo that small would get up that high, my 05 courier only gets to 23psi free boosting but dont do that much.
he does goo job of pumps to have put on two that i have had from him oto different wagons an defantly makes good difference
cheers Jacob
Ideally, you want to use the biggest air-cleaner you can physically fit under the bonnet. Donaldson unit 12 or 14 inches long etc, paper element for best filtration. K&N have very poor filtration in comparison, but have better flow because of it. If its a 24V Safari, you can shift the LH battery to the RH side and turn them both 90 degrees so they sit side-by-side, then you can fit the Donaldson.
With a standard pump, anything above 14-16psi is a waste of time.
hey guys
yea i dont run that high a boost normaly just wanted to c what i could get and yea there is not very much increase in power from 15ish on so yea no point really but it sounds awsome
not running any intercooler yet would like to get a water to air top mount when i have some spare $ and maybe a new intake plenum...
yea that the plan send the pump up to him to work his magic on it
i need a good filter on it coz i do a bit of beach driving so sand get in everywhere so another thing on the to do list that just keeps growing!!!
cheers guys
Jacob
cheers guys
Jacob
jA- wrote:hey guys
yea i dont run that high a boost normaly just wanted to c what i could get and yea there is not very much increase in power from 15ish on so yea no point really but it sounds awsome![]()
yea that the plan send the pump up to him to work his magic on it![]()
cheers guys
Jacob
thats all good man chuck some pics up of it?
jA- wrote:hey guys
cheers guys
Jacob
If you are getting sand in then have you tried a pre -filter eg nylon shocking over the snorkel? Keeps the big stuff out so can help a fair bit.
no i haven't tried that... i will do tho
Jacob
Jacob
- flyingbrick
Those donaldson pre-filter hats are supposed to be awesome. I cant remember the name of them but there are two sorts- the clear bowls which capture the dirt and the black ones which throw the dirt outwards and then let it drop down out of the filter through these vanes (self cleaning)
The ausies love them due to all the sandy dusty places they travel.
They are also very popular on mine machinery. They pay themselfs off quickly there by extending the time between filter element changes.
yep run a precleaner. we run them on all the earthmorving equipment at work and its amazing how much shit they catch
89 safari swb-4.2 auto..for sale
96 safari swb-2.8t manual..stock
come on fellas it a turbo pics an facts about what you have done etc, not about precleaners i knoe they are handy but on nother subjects
just chuck some pics of you turbo safari up "J" pipes what ever just put them up show an tell so to speak
cheers abe
cheers abe
half you fellas on here are all ideas an go on about shit put people down with all ur techno bullshit, i put this post up just to see how people can do it themselfs as is not as hard as most of you lot in here make it out to be
so you balls out fellas post some pics?????
or you all just big bunch of girlly pussies?????
Ok, I'll bite.....
Maybe you should make with the photos of your own setups that you keep going on about first. You know, the photos you promised numerous people on here months ago but keep making excuses as to why you can't provide them.
Think about how you can contribute to the forum, before you demand anything from it.
GQTROL wrote:Ok, I'll bite.....
tui_man2 wrote:have few pis etc of the kits etc that i can do an different set ups if you want to know anyhting just as but im sur most of you on here already know
dont know why im putting this on where or started it just was out of interest but im sure most of you have your own ideas set an is pointly my trying
but here goes...... what you guys think????
link is:
http://www.offroadexpress.co.nz/builds/ ... urbo-setup
as it the easyest way i found to put them on sorry
cheers abe
Not so Taz. I understand Flyingbrick and a few others are still waiting on something specific from him.
If pics can be posted on there then they can be posted in the thread. Pretty easy if you can follow the simple instructions which are on here somewhere. I hardly read this thread anymore as its always pics please and nothing ever comes of it. Have looked through the ones already up and can't see much in them as it won't let me expand them. Can't tell what the quality of the fab work is like for example. Just host them on photobucket and copy the link!!!!!
Theres nothing wrong with mentioning filters either is there as it all goes hand in hand with each other I'd have thought.
- flyingbrick
this is what i mean most you guy are just gay homos
- flyingbrick
Shouldn't you be able to tell US the facts since you are the only apparently straight one here and also since you have made 100's of successful manifolds that you forgot to take pics of.
Also BTW if you are going to insult people do it properly. A gay homo? come on. Thats like me pointing into the kitchen and going a COLD FRIDGE or walking down the street and going AN EMOTIONAL EMO or hang on what about our coffee table.. Made from a piece of wooden wood.
where do you live? Gore? Perhaps the spellings not your fault. Perhaps its that your 3 fingers are a typing hindrance.
Up side is that you are probably a fast as shit swimmer with your webbed toes.
-Nathan
-Nathan
flyingbrick wrote:Shouldn't you be able to tell US the facts since you are the only apparently straight one here and also since you have made 100's of successful manifolds that you forgot to take pics of.
-Nathan
Do I smell bacon!!!!!!!!!!!
And it is funny when someone is asking for ideas so that he can steal them to sell to others, and then gets his skirt all twisted when people don't fall over themselves to help him.
But I guess he just can't express himselve right due to the 3 fingers?...... Yeah Right!
Far from being "gay homo's", I think you'll find most people on this forum are actually very reasonable and quite happy to offer assistance where they can, provide some good tech info along with a bit of good-natured banter.
Oh, but then there are others who are a bit grumpy and likely to just tell you to f#ck off on the horse you rode in on.
But look, the Top of the South Island winch comp is coming up later in the year. Since its right in your own back-yard it will a perfectly opportunity for you to front up and put your money where your homophobic mouth is.
-Nathan
Is a Gay Homo a double negative (not that I am saying being gay or a homo is a negative, Im just saying ... ah feck it)?
So that makes us all straight, right?
darinz wrote:Do I smell bacon!!!!!!!!!!!
Thats what I thought might have been a possibility. You'd feel a bit ripped if your designs were cloned and sold without you getting any credit right. You have to put something on the table before people will open up. I mean its a bit sus when this thread is pretty much all you post in and you want our pics?? Just be normal and stop all this stupid gay homo comment shit as you just look like a child. Treat people normally and they will most likely do the same in return.
-Nathan
nice one mate this is the shit i mean, just nosey time wasnt idiots
haha nice one mate you guys dont want to show just cause your are usless excuse of a weak needed human thats ok
Swamped wrote:darinz wrote:Do I smell bacon!!!!!!!!!!!
thats what i have done have posted pics an was waste of time, was purely interested in seeing how other people has done it.... i DONT want ideas, why would i change something that i have done an i know that it works?????
