k&n pod air filter on 1kzte
for road use is it safe to put a k&n pod air filter on a 1kzte in a kzn185 surf sumwhere in cold air?
Re: k&n pod air filter on 1kzte
Its not going to hurt it as long as your not using it off road through rivers ect, problem is you would have to build a cold air box to keep it cool so id recomend going for a k&n panal filter to fit in the factory air box. you can always put a snorkle onto it to get cold air to it and you would have no wories if you get the temptation to cross the odd river.
027 337 0579
