Just wondering if any one in NZ has pulled off a body lift on a MU.
Details on how to go about it and what materials to use.
Azar
Body lift on a MU??
Body lift on a MU??
Nissan Terrano stock standard kind of.
Re: Body lift on a MU??
yea im doing one very soon ill write up how i did it pretty easy though!! on my mu theres two bolt holes ready from factory so the radiator can be dropped!!
- mud_slinger
you'll have to go buy nylon blocks that are as high as the lift you want and longer bolts and do one side at a time , havent done one mine was already done wen i brought it
needs more curry
0272593533
0272593533
its eazy as to lift ok now this might sound like pretty rough but it got certified at the hardest cert place in chch flew thru. remember to loosen all bolts before jackin it up. this might not be the best way to do it but it worked for me just jacking up one side at a time. theres 10 bolts in total all i used was 2 $12 nylon chopping boards from mitre ten run 60mm hole saw thru stack up to required lift height. u dont need longer bolts factory ones are tons long enuf for 55mm lift apart from 4 in the back from memory which are shorter than rest of body bolts. so just go grab some factry length ones off the body of another one and ur set. only thing i had to extend was the body retention brackets which i cut n den welded with $50 warehouse welder lol yeah i know it sounds ruf but it works the nylon doesnt compress the bolts hold the blocks hard on eachother and i sprayed them black to hide them a bit and bingo all certified. doesnt take long to do but remeber ur bumpers arent gonna line up i extended them again using my $50 welder and they are strong as.
I take no responsability for you not getting certified or anything going wrong i am just stating what worked for me and if you dont like it thats fine go pay your 500 bux or so to get someone else to do it + 350 for cert if u like lol
