purchasing bolts and coil spacers
Weasel
Post by Weasel »
I'm looking for somewhere in Hutt/Wellington to purchase 8.8 grade bolts from for when I need em for hooks, bumper mounts etc. Where do you get em?
I also need to put some coil spacers in front of Vitara since it sat down a bit with bar on front (even with heavier Tough Dog coils). Anyone know where and how much for some metal ones or humpy ones?
Re: purchasing bolts and coil spacers
Weasel wrote:I'm looking for somewhere in Hutt/Wellington to purchase 8.8 grade bolts from for when I need em for hooks, bumper mounts etc. Where do you get em?
HUTT
Steel and Tube in LH just at the bottem of the Normandale over bridge where it crosses the motorway, I dont know the name of the street coz I'm not from the Hutt :oops:
WGTN
Shrodoco Fasteners in Tory St betwwen Vivian st and buckle st, I think they may trade under a different name now?
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Steel and Tube Fastening by the Normandale overbridge for the bolts. Any engineering shop should be able to make you spacers. But if you want to talk to an engineer who knows 4x4's inside out there is only one choice, Brian Howatt at Howatt Engineering in Naenae.
Weasel
Post by Weasel »
Cheers guys
Try Stinky (Marty) as well 384 4141 he can do that and has those bolts in stock I think as well
lneil
Post by lneil »
Another really good source for nuts/bolts etc. is BLACKS FASTENERS, if there is a branch in your neck of the woods. They have virtually everything in stock.
nstg8a
Post by nstg8a »
lneil wrote:Another really good source for nuts/bolts etc. is BLACKS FASTENERS, if there is a branch in your neck of the woods. They have virtually everything in stock.
if you go to blacks try and find someone with a trade card, we have one here and when i got the bolts for my lift kit i got 65% off.... makes a hell of a difference...
jumper
Post by jumper »
Shrodoco/Tonys auto centre same place very good or
Hylton parker
Wellington
Unit 4, 27 Centennial Highway, Ngauranga Gorge, Wellington, NZ
Phone: (04) 499 3293 Fax: (04) 499 3299
E-mail: sales.wellington@hpfast.co.nz
Opening Hours: Mon-Fri 8:00am - 5:00pm
Long bolts for a body lift were going to cost $100 at tonys auto and a few other places, hylton parker did them for $36
microwaved cheese on toast
Return to “Tool Shed”
