i am going to turbo my ln106 2.8 diesel hilux (3L) and have everything i need
for it to happen i have a diesel pump off a 2.4 turbo surf the one with the boost compensator on the top
i dont know much about this side of things but as ive been told the boost compensator can
be put on my 2.8 pump? or do i just put the 2.4 pump straight on my 2.8 and crank the fuel?
whats the best way to go about this? Cheers
2.8 hilux ln106 turbo diesel pump
Re: 2.8 hilux ln106 turbo diesel pump
I just turned up the 2.8 pump 1/2 a turn on my one,seems to be fine,install a Exhaust Gas Temp gauge tho,if it runs over 550c for to long you will have motor troubles.
