Hi - as we are moving to greener pastures, my Nissan GQ is up for sale - specs are:
1/ Engine: 1996 Chev Corvette 5.7 litre V8 with OBD1 computer, pro-coated block hug headers, big bore exhaust, 4 inch steel snorkel with Donaldson Air Filter, Twin electric fans with kill switch for river crossings. Two independent low water sensors fitted to the radiator.
2/ Tuning: OBD1 onboard computer can be reprogrammed with software called “Tunercat” and diagnosed with software called “Datamaster”. Both software packages come complete with full instructions and a laptop with connecting cables.
3/ Transmission: Standard Nissan 1997 GQ manual 5 speed gearbox fitted with Marks Adaptors 43% reduction crawler gears to the low ratio box.
4/Clutch : Heavy duty chev pressure plate, sprung centre cushioned ceramic clutch plate, Chev release bearing, and slave cylinder kit fitted April 2007 (141900 kms) ex Australia
5/ Diffs: 4.625 ratios with ARB front and rear lockers with heavy duty kit fitted to the rear line
6/ Winch: PTO winch with steel cable fitted into ARB front bar
7/ Tyres: 35 inch Cooper STT mud tyres, fitted to 15 inch steel rims bead locked and quick release air tractor tubes. 31 inch Roadmaster Roughneck AT’s on 16 inch alloy Nissan rims
8/ Communications: CCVC club radio A band, 5 watt PRS, CB radio also fitted is an Alpine CDA 7852R Radio/CD unit
9/ Body: 2 inch front and 3 inch rear suspension lift, and 2 inch body lift, all guards cut and trimmed for 35” tyres, rear quarters trimmed for a purposed built rear steel bar which wraps around the sides and gives corner protections. Two front and one rear 10,000lb rated tow hooks, steel side bars
10/ General: Electric radio aerial, electric wing mirrors, electric windows. Rear seats removed to allow spare tyre to be fitted inside for better weight distribution. Spare tyre can be fitted back onto the rear door and rear seats can be refitted, if required. Internal roll bar, strengthened rear pan hard rods, front steering link, front diff and many others. Raised diff breathers, fire extinguisher, Endless air system with tank capable of running a rattle gun, pumping tyres etc. Detachable tow bar coupling. Waterproof front seat covers fitted, current CCVC vehicle inspection sticker. Uniden vehicle alarm/engine immobiliser installed
Note this vehicle is fully certified, including the bead locked rims.
Nissan Safari 1997 V8 for sale
2001 Mitsubishi Diamante VRX Sport
Re: Nissan Safari 1997 V8 for sale
hw much?
Wow nice spec list - if I had sunk that much time effort and money into a truck I would forget about selling it and look at how much a 20ft container and shipping is.....
wow! impressive list of mods. be sad to see that 1 go. how much?
i wont even ask how much, its out of my reach.
stunning looking truck tho
99 pajero exceed 3.2
- gary_in_nz
gidday,
do you have any more pictures?? what was the km's on the body?? cheers
yes I have plenty of pictures, the kms on the truck at this stage is 146,902
Maybe let me know your email address and I can email you some pics
- gary_in_nz
hey, worthog did you end up selling your nissan??
No not yet, just got back from Aussie last week then I have had an operation last Thursday, so I am in recovery mode now. Once recovered I will concentrate on the sale and advertising
Are you interested ?
- gary_in_nz
yeah i am, might give you a PM later on, was just tossing up whether to turbo the td42, or go the whole hog and go v8. what sort of range do you get from this? what size tank? cheers
- TheDarkSide
- Bush Crasher
Hey,
I am also still interested. What sort of price range are you looking at?
Pete
Pete
Best to pm me and we can discuss
