Anyone know where I can get a speedo recalibration step-down box from. And don't say the Speedo shop in Hamiltion, they won't do it unless I take the bloody wagon to their shop, probably so the sods can charge me a fortune for playing with it.
I just need a 1.06:1 step-down that'll fit a Pajero or one that can fit between two cables
Speedo recalibration Shop
- mroffroader
Re: Speedo recalibration Shop
When you find out who does them can you please let me know as i also need one
I have run up a telephone bill to rival the national debt... OK that may be overstating it a bit
Anyhoo I found an outfit that will do the box and it will screw directly to the speedo cable output on the gearbox. A real simple fit job. $180 + GST I've ordered one and it will be about a week. I'll test run and take pics
And that is the last thing I need for the revinning! Woohoo!
The Company is in Auckland
Robinson Instruments
09 377 1565
09 377 1565
- IcedJohnno
- Trailer Trash
Yo
The other place that would be able to help with this is Parrotts in chch
Parrott E & Son Ltd
360 St Asaph St Christchurch
0-3-366-9554
Facsimile 0-3-366-9554
They call themselves Auto Instrument specialists and are damned good. Been round since Adam was a cowboy.
This is where I get my pyros etc.
Parrott E & Son Ltd
0-3-366-9554
http://www.superlift.com/accessories/truspeed.asp
I know the unit works for Jeeps, Fords, GMs, Toyotas - don't know whether it works for Mitsis, but worth asking them. I am using this on mine and it give me the most accurate reading yet.
Also have a look at this:
http://www.dakotadigital.com/index.cfm/ ... prd126.htm
This is similar to the unit above, but half the price.
TJ wrote:http://www.superlift.com/accessories/truspeed.asp
Those are digital, mine is cable mechanical, so they're not a lot of use to me, but looking at the price of them I wish it was digital.
IcedJohnno wrote:Yo
Parrott E & Son Ltd
0-3-366-9554
Thanks for that Johnno, I have to get one for my Niva as well. Gone from 175-75s to 215-80s and the difference is pretty big. So I'll try these guys and make a comparison.
I took mine to my auto sparkie and he adjusted it an it cost about $90.
I dropped the truck off they drove it over timed KM and then reset the speedo and then timed it again. They then provided a cert for the engineer so that I could be legal with 35's.
That is with a Nissan but it isn't always cheaper to do it your self.
darinz wrote:I took mine to my auto sparkie and he adjusted it an it cost about $90.
I think probably like most Nissans, you can do bloody near anything to them by plugging in a laptop, it's what makes them so easy to tune. However, unfortunately for me, the only solution is mechanical because my speedo is not electronic. It's simple check generally, just by checking with the back end of your gearbox: Is there a cable coming out or a wire. Most swapped somewhere in the nineties and mines a '92 model
I got my adapter box from parrotts in Chrischurch, $250 all up, which included them doing a rolling road to check for it before and after
Who knew Prados could fly?
if you own a patrol there is a potentiometer in the top of the cluster thats alters your speedo .i used a gps to get 100kph then used a small screwdriver to alter it .i had to drill a small hole in the outer plastic case so i could adjust it on the move .easy peasy
