high works well, no worries there, just in low, pops out all the time, bit of a worry when on steep hills
Jerry wrote:is it vacuum operated? check the 2 solenoids are working and there are no leaks in the pipe?, they should be under the dash next to the brake booster
turoa wrote:Jerry wrote:is it vacuum operated? check the 2 solenoids are working and there are no leaks in the pipe?, they should be under the dash next to the brake booster
OUT OF LOW JERRY
the vacuum only controls 2wd-4wd
skid wrote:turoa wrote:Jerry wrote:is it vacuum operated? check the 2 solenoids are working and there are no leaks in the pipe?, they should be under the dash next to the brake booster
OUT OF LOW JERRY
seems Jerry may be in need of some new glasses
he's not reading too well lately
fweddy wrote:Do you have a body lift? Sometimes that means the lever doesn't go in right as hard as is ideal and could tend to knock out
basics wrote:that maybe the reason, although its only not long ago started doing it, where as ive had the lift for ages
