winch clutch engage actuator
haynzy
Post by haynzy »
Ok all you 4x4 gurus who has a cunning plan on a remote clutch engage on a lowmount winch
minefield
Re: winch clutch engage actuator
Post by minefield »
Are you refuring to a cordless remote ??
Nissan Safari SWB Auto ,50mm suspension Lift , 50mm body lift, 12000lbs winch,
33x12.5x15 Perilli scorpion muds
rokhound
Post by rokhound »
Or a PTO?
Years ago I made up some relay rods that had a lever handle on the bull bar, and a chain link that attached to the clutch pedal shaft for a PTO on my 60 series cruiser. Meant I could control the winch from the front of the truck, and was real handy for re-spooling the cable back on the drum.
Muzza
Post by Muzza »
haynzy wrote:Ok all you 4x4 gurus who has a cunning plan on a remote clutch engage on a lowmount winch
Anyone awake out there ?
or has this been covered somewhere else.
Rig up something so you can engage or freespool the winchdrum clutch from within the cab.
How did you get on haynzy ??
Cheers Murray
darinz
Post by darinz »
Depends on the winch but alot have an air freespool available.
Muzza
Post by Muzza »
darinz wrote:Depends on the winch but alot have an air freespool available.
I didn't know that you could buy air freespoolers.
My winch is a Runva EWX 12000. ( not quite in the same league as yours but has been very reliable to date ).
Had a look on their website but doesnt look like any available. Will do some searching to see what else is available but I have onboard air so could rig up something with that or even cable activation because it only needs 90 degree movement.
Just wondered what others had made up and saved some $$$$'s.
Cheers :)
dazza85
Post by dazza85 »
if you have air available a small air ram to operate the the lever (or a extra piece mounted to the current lever) should be fairly easy
Muzza
Post by Muzza »
Yeah
Air ram looks the way to go. Have even seen them made from screen door closers.
Any thoughts on a switching valve. :?
Some bugger out there must have a nicely sorted system. Just have to track them down and get a photo posted.
Return to “Tool Shed”
