4inch SWB lift pricing
ToYoda
Post by ToYoda »
Any ideas on the costing up of a 4inch lift on a SWB 94 prado
DieselBoy
Post by DieselBoy »
Try sending an email to:
http://www.genie4x4.com for Tough Dog stuff
or
http://www.fullyequipped.co.nz for TJM stuff
You could also try
www.http://www.4wdconcepts.co.nz/Tough_Dog/ ... shocks.htm
These guys are the importers of the TD stuff from ozzie. You would by pass Genie4x4 that way :wink:
You could always just by a Nissan??
Pete.
ToYoda
Post by ToYoda »
you could always by a nissan
:shock: haha im not stopping that lowwww....Surely a nissan would make it worse
(42 traverse) :lol:
DieselBoy
Post by DieselBoy »
Hey it was driver error that i fell of that bridge, nothing to do with the vehicle!!!
Did i just admit i'm a crap driver????????????????????????
wjw
Re: 4inch SWB lift pricing
Post by wjw »
ToYoda wrote:Any ideas on the costing up of a 4inch lift on a SWB 94 prado
I'm slowly getting prices now... but my best guestimate at the moment is $800-1200 (for LWB)
Chamberlains in Christchurch can supply everything ;)
Who knew Prados could fly?
DaveM
Post by DaveM »
Chamberlains are a good choice, but unless you take your vehicle in to get custom springs made, you'd might as well buy from the closest shop.
I now run Dobinson coils (GQ), and have found a big difference between these and my old Tough Dogs.
Got the coils for $200pr as the original TD's were too stiff and Genie refused to sell me lighter ones because the heavy duty were recommended for my SWB :?: :!: so if going for TD's I would go through 4wd Concepts who seem to have better info. Will be picking up a set of Pro Comp shocks in oz next week which should make the handling even better ($125aus ea).
I would look into it carefully as there are a lot of choices with the rates,linear/progressive, and then you have to get the correct shocks to suit, then, if its like the swb Safari's, look as to whether or not you need adjustable panhards etc etc with this size lift
Dave
DieselBoy
Post by DieselBoy »
Good point with the adjustable panhards.
Yes Andrew, i would say you most definatly will need them for the 100mm lift.
You've seen how both my front and rear diffs are off set to the side after the lift, only by about 10 or 15mm but still noticeable if you look.
I would say you are usually batter off to go for the 50mm raised height spring.
Do some ringing around and see what is recommended.
Be aware, 4x4concepts are nissan specialists, so you may not get much sense out of them.
Runt
Post by Runt »
hey i have a set of 4 inch lift springs for a safari?? they were to high, i couldn't get into carparks. i don't have shocks thou. interested elevnteeen@hotmail.com
