So go to pull the front drum off my sj410 and it doesnt seem ta want ta budge at all just want to check that it comes off just like any other, ie the only thing holding it on is the 6 wheel studs and those little screws. Plus I was wondering if someone could explain to me the purpose of the whole thats in the drums which is as big as a nut on the front panel which you can access with the wheel on as there is a matching hole in the wheel ?? puzzling.
Thanks
stupid question
Re: stupid question
Never mind solved it
Re: stupid question
If its the hole i'm thinking of its for adjusting the brakes
Stick a screwdriver through and you can turn the adjustment knob...
