cruiser 3.4 eng to surf box
taz01
Tazzles
Post by taz01 »
does anyone know if a 13bt engine will bolt up to a surf gearbox just an idea i had...........surf is ifs :?:
WARNING:
Re: cruiser 3.4 eng to surf box
I've a funny feeling Niblik has recently done it to his Cruiser thats been under restoration for the past 10 years :wink:
V8 it
skid wrote:V8 it
Like he says, a nice little 305 would work well and I think I might know of one coming up soon :mrgreen:
Sadam_Husain wrote:
skid wrote:V8 it
was really thinking 1UZ
taz01
Tazzles
Post by taz01 »
Sadam_Husain wrote:
skid wrote:V8 it
I could if i had cash but already have the 3.4 turbo and i think jumper may be looking for an 8 whatever i do needs to be done before QBW and i liked the white surf ............ :lol:
WARNING:
Lexus V8 is $900 - $1400, adaptor plate is $200-500 depending on which one you want ....... not that i've been looking :twisted: what about a 1kzte?
Hey Taz... maybe this will fit.....you might need a roll or 2 of duct tape :twisted:
http://www.trademe.co.nz/Trade-Me-Motor ... 390167.htm
(copied from Ryans thread)
taz01
Tazzles
Post by taz01 »
must be someone on here thats done it please..........save me alot of work if its been done
WARNING:
taz01 wrote:must be someone on here thats done it please..........save me alot of work if its been done
Havent you got your reading spec's on Tony or dont you read the posts above? I'm guessing a 13bt is the same block as a 3b?
Sadam_Husain wrote:I've a funny feeling Niblik has recently done it to his Cruiser thats been under restoration for the past 10 years :wink:
niblik wrote:hello.. time for a little installment of 40ness..
after a great heads up from mad mike,i was able to locate a bellhousing from a dyna to pair the 5 speed lux box to the 3b 'power' plant.. :lol:
when first fittin it together i tried to adjust the metal spacer plate that fits between the bellhousing and motor to fit the starter, but when turnin it over, a rather 'cringe causing' GRAKKK was to be heard.. plan 2. stole the flywheel, metal spacer and all clutch components (as new) from rusty's drive train and stuck it on... adjusted the housing (ya can see the slotted hole) to match the metal spacer plate thingy and turned it over.. SWEET!!! :twisted:
next i had to dremel just a tad off the bottom of the clutch forks mounting ball thing and then bolted the housing to box, and all then all that to the motor.. as below pic shows.. i've left out the clutch and pressure plate for this fitting to see how the spindle fits, then will refit with clutch etc for spline checkin etc.. i would of checked it there and then but work was beckoning.. will know more soon..
BJ40 build thread here (page 25)
taz01
Tazzles
Post by taz01 »
yep blind was hoping for the answer like.........yep bolts straight on but will find out soon enough cheers marty
WARNING:
