10th & 11th May
xj
10th & 11th May
Post by xj »
1) Replaced upper rear control arm bushes. Have spare lower rear if any Jeeper needs em, too big for my aftermarket arms.
2) Re-affixed uhf antenna mount.
3) Fitted JKS Quick disconnects... had a good stretch, the only thing that stopped me was that I ran out of brakeline!
4) Purchased 30 "JP" magazines for $60.00 on TM.... thats $2.00 per mag!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
turoa
Pyro Junior
Re: 10th & 11th May
Post by turoa »
today I pulled the motor from my range rover. Seems Nigel is even better at blowing motors to bits than I am :shock: , 2 rods and 2 holes :lol:
Re: 10th & 11th May
turoa wrote:today I pulled the motor from my range rover. Seems Nigel is even better at blowing motors to bits than I am :shock: , 2 rods and 2 holes :lol:
COME ON, FILL THE BOYS IN WITH THE EXACT DETAILS. IT WAS RATHER EARLY IN THE MORNING TO CRUISING THE MOTORWAY IN THAT BEAST WASN'T IT :?: :?: :?:
I saw another one coming down the road towards you after I went past, looked identical
turoa
Pyro Junior
Re: 10th & 11th May
Post by turoa »
exact details were it was going into town to get a warrent. Sorry to dissapoint you skid, but it wasnt exciting :wink:
And I saw the blue one go past aswell. He was probably laughing to himself about his one working
nstg8a
Re: 10th & 11th May
Post by nstg8a »
havnt achieved much just yet, just removed front bumpers to give me clearance, il take it out tomorrow and see if it worked... :twisted:
swampa
Re: 10th & 11th May
Post by swampa »
put the lux on the trailer as it is off to dunedin in the morning to spend the week at the turbo shop getting dyno'd and tuned, maybe some other work as well
lneil
Re: 10th & 11th May
Post by lneil »
Spent all day on a 4WD demo-day for work. Pete & Deb Ritchie from Natural Instincts in Rororua came down and did it, through Suzuki NZ. Really good day, but frustrating as hell when you'd rather be out doing it yourself. Still, it's cool seeing the look on peoples faces when they've never been in relatively extreme situations in a vehicle before, and the way they can't stop grinning and chattering when they get back.
Hopefully tomorrow I'll be able to get the engine out of the parts truck and stripped down.
dazza85
Re: 10th & 11th May
Post by dazza85 »
Well having trawled through the site for ideas I finally started on the storage units for the back of my Isuzu ...
What I found surprising is the amount of gear I carry around ...
Just have to fit the lids to the right hand side one, remount the fire extinguisher and fix an issue with the seats not tipping up because it is to tight a fit against the box.
It worked fine when there was only the left box in place :oops: :oops:
As I get time I am going to make a unit that fits between them and is the same height as the folded seats for when I go away.
I am also going to make a panel that can be fitted across the seat that makes a platform long enough to sleep on.
PR
In the crap again
Re: 10th & 11th May
Post by PR »
Hey Dazza I am not 100% sure but you may not get a warrent with those boxers past the seats and also do the seatbelts touch them at all cause that will be an instint fail
(021) 02388443
dazza85
Re: 10th & 11th May
Post by dazza85 »
PR wrote:Hey Dazza I am not 100% sure but you may not get a warrent with those boxers past the seats and also do the seatbelts touch them at all cause that will be an instint fail
The impact on the WOF is something I had not thought about :roll: :roll:
The seat belts do not touch the box's, that I did check.
and the height of the box's makes them great armrests but that won't count.
Best I have a talk to the WOF man without the box's in place and see what he says ...
The temptation is to take the back seats out, but they come in handy occasionally.
Dace
Re: 10th & 11th May
Post by Dace »
Just my opinion but i think you will have to radius the edges and maybe do something with the hinges so ya can't hurt ya self on em if things go pear shaped
personally, I have spent the last 2 months upgradin the hilux, and, having figured out Photobucket, heres some update pics
a whine in the gearbox, 3rd and 5th (been there since I bought it) had seemed to be getting worse so decided to pull and strip the box and found this gem :cry:
the gears etc were still ok, lucky enough :roll: , so put a bearing kit in it, refitted and no more whine (unless the wife is in the truck!!)
have also fitted 33' Goodyear MTR's and a "50mm" lift kit and shocks, although It has lifted more than 50mm
any way, I had refitted the Runva Winch a few weeks ago and started building the Bullbar around it, almost finished, just need to tie the main bar to the lower chassis mounts,add the lower loop bar, add brackets for indicators and spots and paint the whole lot black and then bring on the 4 wheelin
curly12
Re: 10th & 11th May
Post by curly12 »
I keep telling you 2's, do it once and do it properly :D
Hopefully this has ended you obsession with Landies :D
xj
Re: 10th & 11th May
Post by xj »
well, this is kinda related to 4x4's....
On the way to taking my wife out for brunch for mothers day we saw a young skinny weedy little white fella having an altercation with an old bloke on the side of the road. He took off and the old fella tried chasing him. The wife was driving (in her jeep) and decided that something was up and we ought to go have a chat to the young fella (i just wanted a feed!).
He ducked up an alley way off a side road and in order to get him to stop Kat full on cuts him off, missing nailing him by a matter of inches.
We have a chat and before I could get out he bolts.... to a dead end.... thank god he could jump! Over a retaining wall he goes, while Kat manages to stop right where he was standing. "Bugger me1", says I," Im not jumping over no bloody walls..." So we head back and have a talk to the old geezer, who, it turns out, owns a backpackers that this young dude has just robbed. The wifes fair got her dander up and so we head off again to hunt/run him down.
Long story short, the police caught him hiding just over the wall that he'd jumped (BUT i maintain, had I gone over too he would have carried on running, which probably would not have good for either of us!!) He was on Police 10-7 two weeks ago for various fraud and theft warrents!!!!
The wifes stoked, reckons running down crims in the Jeep is possibly more fun that offroading.
I eventually got to have my feed.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
basics
Re: 10th & 11th May
Post by basics »
heading to out hunting block at 5am, came around a coner on a gravel road in the day and in the raid to find a fallen tree blocking the path, got past that after a bit off farkin around. ending up walking around for 9 hours to see a stag, get two dogs ripped up and lost 1200bucks worth of tracking gear.
all in all, a whore of a day!
99 pajero exceed 3.2
Dace
Re: 10th & 11th May
Post by Dace »
Right, bullbar fab is finished, just unbolted all the bits and sittin on workshop floor, just need to finish off some of the welds, grind off some of the visible ones, paint it black and chuck it back on again
lilpigzuk
Tiger Balm
Re: 10th & 11th May
Post by lilpigzuk »
took mum for a quick strop in the zuk round my property for mothers day, failed a hill climb and slid backwards into a tree, my first drive in it and I break the tailgate :oops: , and then dad had too pull me up the hill in his landy. Im so gutted :cry: ....... :mrgreen:
turoa
Pyro Junior
Re: 10th & 11th May
Post by turoa »
lilpigzuk wrote:took mum for a quick strop in the zuk round my property for mothers day, failed a hill climb and slid backwards into a tree, my first drive in it and I break the tailgate :oops: , and then dad had too pull me up the hill in his landy. Im so gutted :cry: ....... :mrgreen:
LMAO, nice one rexo
Moriarty
Re: 10th & 11th May
Post by Moriarty »
xj wrote:well, this is kinda related to 4x4's....
CLIPCLIPCLIP
Well done XJ and wife,
you got a good one there, Mark, she's a keeper for sure.
xj
Re: 10th & 11th May
Post by xj »
Moriarty wrote:you got a good one there, Mark, she's a keeper for sure.
Yeah i reckon, shes a patient woman too, 10 year wedding anniversay coming up in December. I thought she woulda fired me by now!!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
TJ
Re: 10th & 11th May
Post by TJ »
xj wrote:I thought she woulda fired me by now!!
Why would she when she has finally broken through and gets you to do what she wants you to :lol: :twisted: :lol: She would have to start all over again (not smart thinking). Ten years, you are a spring chicken, we just celebrated our 14 years about four weeks ago.
Mine has yesterday given me the okay to replace her aging Honda. :mrgreen: She has set very simple criteria for the replacement:
- it should not be smaller than what she drives (CR-V);
- it has to be an AWD/SUV; and
- it cannot be significantly larger than what she drives.
I think a Cherokee (or even a Grand Cherokee) fits the criteria. Now the hunt begins to see if we can find something reasonable within our budget. I have been given three months to accomplish the task.
PS: Given that I got the permission over the weekend to get another 4x4 qualifies me posting it here.
xj
Re: 10th & 11th May
Post by xj »
and TJ, while we're at it, can you have a peek in your FSM (seeing as how I still dont have my driver working on my laptop) and see if there are part numbers or specs for the front brake line fittings. Cant be buggered taking one off to use as a comparison, and the guys at APEX couldn't be arsed stepping out from behind the desk to take a look. Need to add aobut 100mm to my front lines for the added flex. Cheers
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
TJ
Re: 10th & 11th May
Post by TJ »
xj wrote:and TJ, while we're at it, can you have a peek in your FSM (seeing as how I still dont have my driver working on my laptop) and see if there are part numbers or specs for the front brake line fittings. Cant be buggered taking one off to use as a comparison, and the guys at APEX couldn't be arsed stepping out from behind the desk to take a look. Need to add aobut 100mm to my front lines for the added flex. Cheers
The easiest way to do that is to actually use the front brakelines for a YJ. They were longer for some reason (probably to get around the leaf springs) and are an exact fit. I'll see if I can find a part number for you.
NJV6
Re: 10th & 11th May
Post by NJV6 »
I got stuck in a river on a club camping run :(
Had to do the 'quick lift all gear off the floor as the water level was rising' trick... The gumboots were just long enough!
TJ
Re: 10th & 11th May
Post by TJ »
Have a read of this:
http://www.stu-offroad.com/suspension/exthose/brakes-1.htm
I think JustJeeps should be able to get these RuggedRidge ones for you:
Right http://www.omix-ada.com/productInfo.asp?itemNo=52006472
Left http://www.omix-ada.com/productInfo.asp?itemNo=52006473
nstg8a
Re: 10th & 11th May
Post by nstg8a »
nstg8a wrote:havnt achieved much just yet, just removed front bumpers to give me clearance, il take it out tomorrow and see if it worked... :twisted:
it worked :P only rubbing is from the flares..
also managed to break one of my mirrors when i had to reverse back down a track... :oops:
but from the first drive in the mud with semi decent tyres, the new whale seems a hell of a lot more capable than the old surf.
xj
Re: 10th & 11th May
Post by xj »
Yeah TJ he can, i just cant afford to take too long. Need em before Queens Birthday weekend.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
TJ
Re: 10th & 11th May
Post by TJ »
xj wrote:Yeah TJ he can, i just cant afford to take too long. Need em before Queens Birthday weekend.
Honestly, you should be able to order directly from a US site and have it delivered before Queens birthday! If he is taking a long time, there are alternative avenues available. May be you should give the dealer a call and see if they have YJ brake hose in stock?
xj
Re: 10th & 11th May
Post by xj »
Im still waiting to hear back from wingers about control arm bushes.... spoke to them on tuesday!
I'll sort something out.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Heath
Re: 10th & 11th May
Post by Heath »
Spent most of today scratching my ass and looking at wires. Decided to clean everything to make the job easier as well.
When I looked into the intake manofold I can see it has had clay dust in there so is there an easy way of cleaning this out without stripping the whole thing down furthur? My Missus reakons this thing is being turned into a bigger pile of parts and will not be running by christmas (Now I have a goal - to prove her wrong).
One step forward and one back at the mo.
Heath
wopass
Re: 10th & 11th May
Post by wopass »
came second in a comp :mrgreen:
uploading a vid now, its not small so not dial up friendly, it does happen to have a singing chev in it and MNC camera man has some profound statements in it :lol: and mat, there was a couple of other people that made it thru that bog but it was the first to hit it when it was fresh apparently ? so me doing it mid day is still pretty cool 8)
vid will be posted in the club class winch comp thread when its uploaded :mrgreen:
