Leaky Terrano Headlight
- Creamygoodness
- Stropper
Hi my Headlight leaks when ever it rains can any1 tell me if its a seal or a headlight at fault,and how I fix it?Thx all
;-p
check the lens for stone chips/cracks. if there is either that will most likely be the problem
if not, check the lens seal and the bit in the back where the bulb goes in, might be cracked plastic or something similar
DONT TOUCH THE BULB WITH YOUR HANDS
very very bad for the bulb and will blow
