I have a 1990 daihatsu feroza and i've been told you can fit hilux shocks to them. I'm wanting to find out exactly which hilux shocks will fit it. If anyone could let me know that'd be bute.
Thanks
Hilux shocks
Re: Hilux shocks
any shocks will do as long as they are eye pin configuration.
you will have to change the bush to a 16mm shaft size i think it is (better check the actual size before you buy) and got to BnT they should have the one your after just have to explain to them what it is that your after.
cameronmaxwell@xtra.co.nz
0274202727
0274202727
