-33 or -19 offset
Engineer
-33 or -19 offset
Post by Engineer »
advantages/disadvantages of going the wider/lesser offset on my ln130surf.
ive got the factory flares on me truck what do ya do if the tires stick outpast them? still fit the rubber flares onto them?
looking at going 33s shortly.
ryan
worzel
Re: -33 or -19 offset
Post by worzel »
If you get the right offset 33s will not stick out from factory flares
Not sure what offset mine are but i have got 15x8 with 33BFGS and they are just inside flare
Engineer
Post by Engineer »
i realise that, would there be any advantage other than a wider stance if i was to go the larger offset? is it worth the hassel?
A new set of rims is a lot of money for 14mm? :oops: :oops:
Engineer
Post by Engineer »
at the moment im running 31in scorpions on my std surf rims so i want new ones just unsure what offset to get.
smurf182
Post by smurf182 »
Some wide body LN130s come from the factory with 15x7s with a -20 offset, so 15x8 -19 shouldn't have the tire sitting too far outside the factory flares, if at all. Personally I'd go for the -33 offset though, as this lessens the chance of a 33" mud rubbing on the sway bar and pitman arm like mine do..
Where did you find a 15x8 with -33 offset by the way? I need new (bigger offset) wheels and don't really want to go for the -44 15x10s on trademe.
Engineer
Post by Engineer »
sorry but im getting 15x10's. my factory rims have +7 offset
id like to for the -33s but really dont wanna have to put flares onto my fibreglass flares
Ryan
UBZ
Post by UBZ »
I'm running 15x8 -18 offset and my 33" BFG's sit just outside the flares on my wide body Surf.
However the flares being fiberglass have been copping a fare amount of damage and will be soon be replaced with rubber.
Engineer
Post by Engineer »
just sat down and worked out how far out a 15x10 with -33 will stick put, and its way too much haha think ill stic with the 15x8 with -19.
Return to “Tyres”
