Carports
dazza85
Carports
Post by dazza85 »
Does any body know what the rules apply when putting up carports ??
Do you need a permit ?
Some people have said that if it is not attached to another building you don't need a permit?
I am guessing the rules are different with the different councils ... :roll: :roll:
Re: Carports
The rules shouldnt be different between the councils coz of the RMA and Building act?
I dunno about carports but you used to be able to build a structure of 10m2 so long as its not used for accomodation or dosent contain potable water ie: a shed but not quite big enough to be a garage?
fred flintstone
Re: Carports
Post by fred flintstone »
I understood, so long as theres no walls, a carport doesnt need a permit... :?:
gotta '93 Mu, 2.8 td, auto, on 31x10.5x15's, and a 40ch CB,(am)
the new toy is, '98 Suzuki Carry, 660cc, 3 cyl petrol, 4x4, on 12" muddies
haynzy
Re: Carports
Post by haynzy »
sorry guys all wrong, carports require permit and any structure with permanant foundations ie concreted piles etc but this is only an issue if selling a property and prospective buyer does a pim report.
best way is to build carport on cast in bomac post brackets then you can un bolt the bugger and shift it if it ever becomes a problem
bigbear
Re: Carports
Post by bigbear »
Check with your local council find out how bigger structer you can built with out a permit, here its 10m2 if iam right. Also one of your local shed building companys like Versitile who do carports would know.
tallsam66
Re: Carports
Post by tallsam66 »
Safest way is to contact your local council & ask them....could be an expensive mistake to just build one
haynzy
Re: Carports
Post by haynzy »
unless your gonna sit it on the ground it needs a permit, these days if you change anthing in your house chances are legally it needs a permit they love to suck the little money we have left after paying through the nose for petrol and cheese getting a permit need not be an expensive exercise though generally speaking our councill here in palmy are fairly reasonable
Return to “Tool Shed”
