Landcruiser 80 Dash Warning Lights Question
suzolla
Post by suzolla »
Hi,
Went for small detour over some bumpy ground with the kids the other day, when I stopped to go back to high range a bunch of warning lights came on, see the photo below. When I increased the revs they all went off.
Checked it out again last night and this is what happens.
Switch on and all the lights come on as usual.
Start the engine and let it idle and the 2 turbo lights and the bottm 3 lights stay on.
When the revs are increased to about 1000 all the lights go off.
When the revs are increased further the green turbo light comes on as normal
When the revs drop back to idle sometimes the lights come back on and sometimes they stay off.
Does anyone know what the cause is.
Also what is the 3rd light from the left at the bottom for.
Thanks
Tim
Re: Landcruiser 80 Dash Warning Lights Question
I would ask a toyota technician, as it may a sequence of warning lights that point out a sepecific problem
and I would check it asap
DieselBoy
Post by DieselBoy »
Those are the same lights that come on when you turn your key to the ignition on position.
To me it would indicate the alternator had stopped charging (i got all the lights on the dash up just like in your pic after doing a deep water crossing at anzac weekend) :idea:
furnace
Post by furnace »
I had the same problem about a month ago,it will be a alternator problem for sure ..mine happened after going through Waipuna Caves,mind you we had been through deep water a couple of weeks before,the auto electrician pulled apart the alternator and found the brushs sticking with silt,replaced the brushs and is now as good as new
The third light on the left is the fuel/water warning light
suzolla
Post by suzolla »
Thanks for the replies, also talked to Toyato who also said it was probably to do with the alternator. So I will check it out tomorrow.
Thanks
Tim
can get them checked and rebuilt if this is a cheaper option than new
mudzilla
Post by mudzilla »
Yep,,Agree with other posts,,Alternator is playing up..Happend to mine..low voltage made the turbo boost and over boost lights come on . :(
suzolla
Re: Landcruiser 80 Dash Warning Lights Question Fixed, Alt Brush
Post by suzolla »
Thanks for all of the replies, now fixed.
$12 for the brush assembly, had to machine the slip rings in the lathe.
All back together and going well.
Tim
