Liftin rear shock mounts
started rear shock mount Lift
Idear is to lift rear shock mounts so its less likely to get bashed on stuff which it does do and side benefit being it well let the wheel drop alittle further for better artic.I have measured shock to make sure it wont bottom out.
Std mount before work started VVV
Mount cut off with cutting disc,cut approx 40mm out of middle section of mount and reused lower section which was welded back to diff. VVV
Lower section welded back in place VVV
Only done right side you should be able to see the differance from left,well do left side this weekend.hardest part was making sure lower section pin was correct alignment so it wont slog out the shock seals.well give it a flex test on weekend so if theres any noticeable change.
