help with 1g-e single cam 6 cylinder into yn60 surf
has anyone out there put one of these into a surf? ive found one for next to nothing i already have the bellhousing to suit just wondering if its guna be a worth while conversion truck currently has 3y in it apart from being gutless it sucks the gas can i use the 3y flywheel, clutch etc?
Re: help with 1g-e single cam 6 cylinder into yn60 surf
jusr doing this swap in to a mates surf, using the 1g motor and bell housing surf clutch plate and 1g pressure plate, has a very basic wiring loom which is good , his is replacing a blown diesel motor .
vaughan
vaughan
spend a couply $$ and go a 5 6 or 7M
Was going to do that had a 5mge but the wife and bellhousing was the killer for me so i sold the engine and put it on the backburner for the last couple of years does someone have a 5mge setup for next to nothing?
