hi there i saw a while back that some guy on trademe was selling complete kits for 2'bodylift for gq swb safaris
anyone know who he was and how i could contact him cheers
2"bodyliftkit for gq
Re: 2"bodyliftkit for gq
hi i am sure this is his trade me name stainless5 .hope this helps
- gary_in_nz
where abouts are you??
west auckland mate
- gary_in_nz
ok, cant really help from Gisborne, but go ask an engineering firm or a mate whos handy on a lathe to make you up some from some shaft, if you can.
I used 8, four that were 75mm diameter, these ones are the 4 middle ones under the cabin as the floor is slightly chamfered and used four 80mm diameter ones for the front and the rear mounts. Run a 13mm hole through the middle and get some grade 8.8 bolts that are 12mm x 150mm with nyloc nuts.
For the back 2 mounts they are captive nuts inside the floor, but apply some heat, I used a paint stripper gun, to break the loctite, then run a 13mm drill through the captive nuts. have a search on the net there are some good guides out there.
one of the online 4x4 sites has them..........can,t remeber which one, 4wdaccessories?
95 Safari on brg 33,s/ 4age e class zuk (old faithfull)/ d class rig under construction.
- gary_in_nz
yeah thats right, here on 4wd bits, Nylon ones
http://www.4wdbits.co.nz/ProductDetails ... uctID=1117
