hey guys first time poster, a lot of great stuff on here tho,
my Y60 has a whine which starts at over 50kph and in 3rd and continues to get more high pitch as you go through the gears, it stops upon deacceleration and coasting and doesnt appear to happen in 1st and 2nd, i also cant nail it down to either the diff or gearbox i have checked for tail shaft and UV play and the backlash doesnt appear to be abnormal in the diff also no metal shavings in any of the oils, sorry for the novel any ideas?
noisey whine???
noisey whine???
Y60 pretty much stock, snorkel spotlights custom bull bar, maxis tyres next step rock sliders and shock overhaul..... live for the country work for the city....
Re: noisey whine???
no sure as its nissan but sounds similar noise to when my toymota transfer case went (noise was caused by hardner being worn off the gears)
toymota thats stock standard.
Re: noisey whine???
its not the co-pilot is it?
(sorry couldn't resist
Re: noisey whine???
proberly a toyota driver in the passangers seat
(021) 02388443
(021) 02388443
Re: noisey whine???
Id say diff, my work van doing the same thing, cant hear anything untill bout 50k and in 4th and 5th
Re: noisey whine???
haha nah its usualy hard to hear a toyota driver from the towed vechile behind you
........ but jokes aside i think dropping the diff might be the next step. does anybody know any more quick tests to check to narrow things down?
cheers for your help guys
Re: noisey whine???
Take the rear drive shaft off run it in 4wd see if it still makes it
Re: noisey whine???
gordo wrote:Take the rear drive shaft off run it in 4wd see if it still makes it
good call there gordo will do tomorrow and see how it goes cheers guys
Re: noisey whine???
Keen to try this test but wouldnt the transfer case spew out oil once the rear drive shaft is removed?
Re: noisey whine???
my terranos got exactly the same problem, I know its my diff, going through drive through today, hard lock turn the rear is binding up and clunking... Not sure how long its gonna last..
