rear sway bar
rear sway bar
just pulled the rear sway bar off ,doesn't look very good bent the buggerey out of it ,can they be put back in shape
Re: rear sway bar
coxsy wrote:just pulled the rear sway bar off ,doesn't look very good bent the buggerey out of it ,can they be put back in shape
Take it to the scrappy. Your better off without it.
MWB V8 Safari Ute
- curly12
Re: rear sway bar
You can have my one Coxsy if you want
Re: rear sway bar
What Doddzee said
Took mine off a cpl months ago and could'nt believe how well she handles on the road
Dont get me wrong its not unnoticeable but it is has a lot better manners than i expected.Would put it on to do a long road trip thru hills though.
Re: rear sway bar
Agree with Doddzee, dump it, if you want one I have mind still hanging in the garage,buts going to the tip soooooon
2001 Mitsubishi Diamante VRX Sport
Re: rear sway bar
gave it a work over today the wofs due , so will hang it on till then
if i need one will give you a nod curly ta
- safaripete
Re: rear sway bar
my wof place failed me for not running my swaybar when i took it off
are some places not to worried about that over others?
he told me as the mounts are there that i need to have swaybar there?
Re: rear sway bar
put the bar in a press a few pushs good as new till the next stump
man the safari stopped quick when you hit those
Re: rear sway bar
safaripete wrote:my wof place failed me for not running my swaybar when i took it off
Some warrant place's must be tuffer than others,got the cruiser wofed yesterday and they didn't care 2 hoots about the sway bar not being there
Re: rear sway bar
Ive taken my terrano to the same testing station for its last 3 warrents, first time no swaybar it passed no questions, 6 months latter i swear the same guy failed it. so chuckd it in, back 2 the shop n got a new warrent 20 mins later then took it st8 back out. third time my truck failed on a long list of stuff but nothing to do with the sway bar, it took me over a month to fix it all so when i took it back they had to do a full recheak n this time it failed on the sway bar so again 10 min job it back it recheak then back out.
Ive talkd 2 several people in the trade n they split on whether you need it or not - so im lost
Scarfies on the piss,
Re: rear sway bar
why not just fit disconnects ?
Re: rear sway bar
Armz wrote:Ive taken my terrano to the same testing station for its last 3 warrents, first time no swaybar it passed no questions, 6 months latter i swear the same guy failed it. so chuckd it in, back 2 the shop n got a new warrent 20 mins later then took it st8 back out. third time my truck failed on a long list of stuff but nothing to do with the sway bar, it took me over a month to fix it all so when i took it back they had to do a full recheak n this time it failed on the sway bar so again 10 min job it back it recheak then back out.
Re: rear sway bar
Apparently if you go for cert now without a swaybar you will fail. Mine was certed before all this. Mine never came with a sway bar. I would take your trucks to a dedicated 4wd shop, you might find them a little more understanding on the no swaybar issue.
Al
Al
Re: rear sway bar
just got cert two weeks ago with no sway bars in mine, and wof obviously
Re: rear sway bar
albundy wrote:Apparently if you go for cert now without a swaybar you will fail. Mine was certed before all this. Mine never came with a sway bar. I would take your trucks to a dedicated 4wd shop, you might find them a little more understanding on the no swaybar issue.
Al
I think you are right Al,the guy i deal with is right into to his 4x4ing and a bit of a hard case but he is not slack on his WOF's i must add,anything to do with safety issue's he is very tuff on,as he said the landtransport [ or who ever ] send people round a few times a year to check they are doing things properly [ like a secret shopper..]
Re: rear sway bar
with the swaybar on and the mtr's, passed a wof no probs so back to the 33' s
