twin transfer cases
twin transfer cases
hi all im looking at goin to twin transfer cases in my hi lux but not really sure how to "plum it all in" is it just a case of adding the second case behind the first one the and away u go i know thats put very simply but is that the go or is a addapter and another leaver needed ???
Re: twin transfer cases
Speak to Jafa http://www.trail-gear.com/transfercase.html
or
http://www.marlincrawler.com/
http://www.marks4wd.com/
or
LR110 ..... LJ50 project
this is what mine look like you need a second stick , will need to change exsaust as the transfer's are longer you will also need to make custom drive shafts
.jpg)
.jpg)
then getting them to fit in the rig
.jpg)
.jpg)
why do you want duals it would be easier for you to fit gears into your transfer case this way you wont need it to be certed
but duals are cool and so are gears , thats why I've got both makes it so much more control in the rocks
.jpg)
.jpg)
.jpg)
.jpg)
lil_tank wrote:hi all im looking at goin to twin transfer cases in my hi lux but not really sure how to "plum it all in" is it just a case of adding the second case behind the first one the and away u go i know thats put very simply but is that the go or is a addapter and another leaver needed ???
You need a second reduction box for the rear that is a top shift, ie the stick comes out of the top of the reduction box, not the one that comes out the front
you basically disassemble the donor case and add the bits to the adapter then bolt it all together. You will need a longer front and shorter rear driveshaft, and possibly floor mods
Heres a pic of mine
Heres a link to the install instructions
http://www.trail-gear.com/tech/dualcase/index.html
and a link to an adapter on our site
http://www.snr4x4.co.nz/dual-transfer-case-adapter-spline-p-168.html
give me a call if you need any more info
Jafa
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
ooooooooooooooooo looks good jafa you need to get some trail rash on those duals
Chopper01 wrote:ooooooooooooooooo looks good jafa you need to get some trail rash on those duals![]()
heh yes sir! we'll rash them up at xmas!
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
What transfer cases can you use - reading the sites it says 21 & 23 spline transfer cases, not knowing my toyota gearbox's more precisely which ones are they? Can two LN130 transfer cases be used? Or do they have to be the earlier ones??
you need two geardrive, ie , no ADD or "shift on the fly" bullshit. The rear case must be a top shift, or you need to get a top shift conversion kit from Marlin
The correct transfer has 7 bolts holding the rearmost housing on
and looks like this
the ones you use are 21 spline input shafts, but you can upgrade them to 23 spline 'specially for the rear case if running 4.7 gears
and looks like this
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
reason im running dauls is i got a spare transfer case cert doesnt bother me its just another thing i'll need to get certed
