samurai carby
For all Suzuki related topics
new2zukes
samurai carby
Post by new2zukes »
well took the zuke for a run today very hilly farm and very slippery and the carby started backfireing and would stall if i put my foot to the floor. everyone said there is just crap in the carby so was wondering if it is that hard to take it apart and clean it if its not too easy then il jsut take it to a machanic i have 2 carbys to clean as i replaced the first carby cuz it was dirty and wouldnt idle and had a spare in the shed anyways.some diagrams would be awsome if someone has any if it not hard to clean.cheers
martin
Heath
Re: samurai carby
Post by Heath »
viewtopic.php?f=23&t=11705&hilit=+carb
Seek and you will find.
This is the red neck fix and it works for dirty carbs but isnt a fix just a get home method. Still need to clean out the fuel line, fuel bowl and filter etc.
The timing belt hasnt slipped has it? Check timing.
UBZ
Re: samurai carby
Post by UBZ »
this web site is your friend
http://www.suzukiinfo.com/
You can just spray some CRC carby cleaner through it, or go the whole hog and re-build it.
QUADRACER
Re: samurai carby
Post by QUADRACER »
Carb kits approx $60
very easy to install, then add a motorcycle fuel filter form the fuel pump
to carb, vent the top air intake to stop fuel returning and this
will fix the problem,the other thing to check is the idle solinoid, by
removing the wiring and listening for the clicking
Return to “Suzuki”
