98 Wizard
For all Isuzu related topics
timotheus
98 Wizard
Post by timotheus »
A friend just bought a 98 Wizzard running the 3.0 t/d (4JG2??)
Just wondering where does he need to keep his eyes peeled for any problems?
It has 160km on it and has a pretty good service history, water pump and belts just done new munroes all round, oil and filters done regulary.
he picked it up from a yard for 5K (seemed dirt cheap to me)
Looks like a smart little trolly (sorry i hate soft roaders)
Anyone have any comments or expereince?
Thanks Tim.
Re: 98 Wizard
they seem to look like stretched mu 's an mu's can do the a bit offroad :D
mudgripz
Re: 98 Wizard
Post by mudgripz »
The 3.0 is likely the 4JX1 motor. This motor gave problems with O-rings in the injectors and was I think subject to a recall. Check for seepage around injector area and check with salesyard the O-ring work has been done - can be expensive if this breaks down.
The 3.0s have electronic sensors for everything, and for this reason are best serviced for all serious issues by an Isuzu agent like Blackwells with all right problem solving diagnostic gear. If O-rings ok, then this is a very good bargain and should give your mate a good run. Peppy truck that can do big ks.
Before heading offroad and perhaps contemplating front lokka, check size of front cvs. Earlier bighorns and mus (87-93) are quite strongly built (about 30mm shafts), but some later models ( depends where assembled ) have lighter cvs and don't handle lockers as well.
Nice truck - easy to lift and develop and can be made to perform quite well offroad with a few $$.
timotheus
Re: 98 Wizard
Post by timotheus »
coxsy wrote:they seem to look like stretched mu 's an mu's can do the a bit offroad
Yeah they pretty much are, it wont see anything more serious than ski feilds :roll:
mudgripz wrote:The 3.0 is likely the 4JX1 motor. This motor gave problems with O-rings in the injectors and was I think subject to a recall. Check for seepage around injector area and check with salesyard the O-ring work has been done - can be expensive if this breaks down.
Thanks for that, Ill have another look at the engine code.
I had noticed all the electric gear under the hood, there is a surprisingly massive heat sink hiding some serious relays (i think). Way different from the old 3L.
I had heard the same about the injector pumps but wanted some verifcation from someone else.
The guy is one of those genuienly nice guys so i hope it serves him well.
As much as id like to see him put a locker in it, chances are the hardest it work is a wet feild......
Return to “Isuzu”
