mudzillas 15x8 or 15x10??
muddyplumber
- Spring Free
Just picked up a bargain a new set of 35x13.5x15 mudzillas for $320 each includin fitting n balancing, at the mo iv got 15x8 white spokes rims will i be sweet to run the tires on these rims or will they just keep popn the bead off, am i best to sell them n buy some 15x10z instead.interested to see what people think
Rich
Rich
Re: mudzillas 15x8 or 15x10??
15x8's will be fine, there'll be more chance of popping beads with 15x10s
muddyplumber
- Spring Free
wicked
what sorta psi should i put in them 30ish??? or that to much.the tire shop guy doesnt reckon i should run much to stop them wearin badly in the centre.
muddyplumber wrote:wickedwhat sorta psi should i put in them 30ish??? or that to much.the tire shop guy doesnt reckon i should run much to stop them wearin badly in the centre.
yeah about 30 ish but it probably wont really matter coz they'll wear bloody fast anyway as all agressive tyres do
Shit that was a good price you got them for
muddyplumber
- Spring Free
got them from KATZ in kaiapoi bloody good to deal with, they sell alot of maxxis tires so they can sell them abit cheaper was gonna get some creepys they were gonna do them for $385 but went with the mudzillas. they wont get used on the road much cos its not ma everyday driver, so hopefully they last alittle while
I got the same tyres as you and put them on 15x10s and air down to about 5-8 psi and haven't had any troubles with them. i like the 10 inch rims cause they stick out a bit further to avoid rubbing
I run mine at 25-30 onroad and start at 10psi offroad, did you get tubes fitted... ps watch out for them on sidelings.... when you stop you will find them sliding sideways, they can also dig out of ruts too. they work best in the mud when they are spinning fast. be careful on gravel roads going round corners fast .... you may notice the back sliding out due to the open tread design.
- Bulletproof
muddyplumber wrote:Just picked up a bargain a new set of 35x13.5x15 mudzillas for $320 each includin fitting n balancing, at the mo iv got 15x8 white spokes rims will i be sweet to run the tires on these rims or will they just keep popn the bead off, am i best to sell them n buy some 15x10z instead.interested to see what people think
Rich
I would use the 8 inch rims because they will clear better. I have 35x12.5 on 8 inch and they are too wide . My 35 simexs are on 7 inch which are much better. My friends run 7 inch with their 12.5s and they are better than my 8 inch ,so 8 inch would be real good for the 13.5s
Cheers Richard
Never say die, up man and try
muddyplumber
- Spring Free
Thanks for all the help looks like il keep the 8z, il use the money i wouldv spent on the 15x10z on some lockers.
havent had the tires fitted is it worth fitting tubes?what sort of cost are they.
Rich
Rich
- cool__bananas
the skinier the rim the lower the pressure will have to be for it to be flat across the ground and bag out more, ive got 35x12.5 treapadors on 10" and another set on 9" and the 10" look heaps widers and work better especialy in ruts, its kinda the same theory as a hot rod tyre, the put wider tyres and rims on so they have more tread on the ground, so why would you not do that with 4x4ing?
- Dr_PC
Okay tip to get even wear on tyres.
In your local SMOOTH carpark concrete driveway draw a line across each tyre do 2 or 3 revolutions and see where the chalk has worn off. if chalk has gone right across tyre that will be even wear and of course if chalk is gone from middle only then tyre has to much air and will wear middle. Half to one pound will make a difference
Now after all that the most important part of the tyre to us 4 wheelers is the edges thats where we gt all our sidebite from so pump them up hard and wear the middles but when you get in the ruts the edges and side will still work.
- hosehustler
I would firmly agree with Bulletproof on rim width, I recently sold a vehicle with virtually brand new 35inch Mudzillas on 15x10's, I would've kept them for my next truck but after running 15x8's with creepy's and BFG at's, and MTR's, over a period of 4yrs and never popping a bead I bought the forementioned and popped a bead first trip out.
I now have a good set of 15x8's to go on the new truck.
I hate signatures
Go with the 8". I used to run 36 x 12.5 on 8" rims and only ever popped one bead. We run at 5-8psi and unlike the trials guys, who are bagging for flotation and extra foot print on what is generally soft , muddy ground, we are trying to fold tyres over rocks, that are sometimes wet from river water. Hence our tyres get seriously out of shape at times. I am now running 39.5 x 15.5 on 8" wide rims, and have never looked like having an issue with them.
