Do you think this would be LEGAL?
brakes-shocks-lockers-etc
Damz
Post by Damz »
Need some advice, I just bought a nissan/datsun navara, which has a small rear diff (c200), I want to upgrade the diff to a much bigger/better/more upgradable/LSD terrano diff (h233b).
I can get the entire h233b axle with LSD diff, discs and all for $300.
Problem is, Terranos are coil sprung, Navaras have leaf springs..
Now this guy has done what I want to do, could you please have a look and tell me if you think its worthwhile, and what would need to be done to keep it road legal?
Thanks!
Link ----->> http://www.cardomain.com/ride/2218930/28
mroffroader
Re: Do you think this would be LEGAL?
Post by mroffroader »
You will need to get it certified, talk to your local certifier and get his opinion on it :wink: The brakes can be certified but i'm not sure the way he's done it is a very efficent way of doing it, you will also need a normal handbrake. The coil mounts are easy enough to cut off and make some spring perches for the leaf's where abouts are you from? I'm sure a local member could help you out :D
tweake
Post by tweake »
why not just get the h233b off a navara, the brakes etc should all be a closer match and will have leaf spring mounts.
Bubba
Post by Bubba »
Damn, I was hoping to see pictures of hot young chicks!! :lol:
Benjamin Franklin
