Hey guys.
Just converted my commie powered ln65 double cab hilux to manual using a ln130 deisel gearbox.
Factory the gearbox runs 4wd to the push button on the gear stick so i need to wire the 4wd up to a switch.
The plug running off the transfer case has 5 wires: 2 Large ones - 1 Green and 1 Green with red stripe.
3 Small ones - 1 Green 1 yellow 1 Black.
Any one wired one up before? or can tell me what the indervidual wires do?
Any help would be appreciated.
Thanks
Nick
4wd wiring help please!
027 337 0579
Re: 4wd wiring help please!
sounds like its similar to the electric locker wiring .the 2 big ones are the motor and the 3 small ones are the limit switchs .search "toyoya electric locker wiring" and see if that helps
i could photocopy the wiring diagram out of my hilux book if you want? whats you email?
thanks guys, i usume a couple of the wires will be for the 4wd light on dash.
wrx_sti95@hotmail.com
nick
nick
027 337 0579
yep some are il send the diagram now
