hey guys just looking at buying this surf and if i go through with buying it, i will be looking into and after looking around the 4x4 shops in chch havnt really come up with anything, i was wondering how easy it would be to source a bullbar for this model of surf and how much it would cost around about.
http://www.trademe.co.nz/Trade-Me-Motor ... 354732.htm
sourceing a bullbar for a surf
Re: sourceing a bullbar for a surf
AS it has airbags you will have to get an airbag certified bar.....could be very expensive...but im no expert.
Could be less hassle to buy a slightly older hilux without airbags
ARB does one for a prado that fits around
$1650 i think i payed for mine
1980 4x4 Hilux Restoration
What do you want to use the Surf for? This will dictate the type of bar required.
Gen 3 Surfs have Airbags so the bar will have to suit.
Your choices are pretty much ARB, TJM or Ali Arc. Prob a few more NZ made ones out their as well. Unless you want to import.
LR110 ..... LJ50 project
I'd say go to your local towbar/bullbar shop and they'll be able to make you something up. Got quoted $760 for a front bullbar with winch mount for a mu when i was looking at buying one and said they could make one for airbags too because i wasn't sure if it had them.
Good luck
Good luck
would a custom bar be a better choice?
rockyman wrote:would a custom bar be a better choice?
IMO it would be, cause you get exactly what you want.
as long as its airbag compatable , i have had to physically show wof guys the sticker on the bar to confirm it is
gimmemud wrote:rockyman wrote:would a custom bar be a better choice?
